#84 vs #85... what to get?.?.?
  • #84 vs #85... what to get?.?.?
    Im about to place a ADS order and wanted to get a bottle of something for the surfaces that will need more then the normal #83/#80 combo. Ive never used #84 or #85 and to me they seem to be similar to eachother.
    What is the main difference between the two besides the obvious abrasive differences?
    If I already have 80, 82, and 83.... which one would you suggest I get just to have on hand for tougher jobs? I did a white car recently and wished I had somethine more aggressive then the #83 that I had to use multiple passes with that didnt exactly get everything out.
    Thanks in advance.
    ----------02' 35th Anv. Limited Edition SS----------
    561rwhp/541rwtq, M6, T-Tops, SLP option car, 1 of 1,037.
    --| TUNED BY FORCEFED PERFORMANCE | Mods: Boost.
    I would go with the 84, it is easier to work with than the 85. The 85 is used with a wool pad.
      Just to double check, how are you planning on applying the M84 and/or M85?
      The reason I ask is because M84 and M85 are formulated for use with a rotary buffer, not a dual action polisher.
        Dang... not for DA. That answers my question then.
        What suggestions do you have for a DA then? ADSs website doesnt specify what its used with, I assumed it would be the same as the M80 and M83.
          If M83 with a W-8006 foam polishing pad isn't cutting it, (no pun intended ), then read this thread and you'll find the answer you're seeking...
          PC + #83 not "Cutting" it! - The Limits of the Dual Action Polisher
            Thanks Mike!
