Applying Scratch-X and Show Glaze
  • Applying Scratch-X and Show Glaze
    Just a quick one to see if I am applying Scratch-X correctly.
    I am only getting rid of fairly like swirls, just apply with foam applicator and rub in with foam applicator until product just about disappears then repeat if nessecary then final MF wipe?
    Showcar Glaze, spread with foam applicator, then rub in with MF cloth, flip and buff with other side?
    for scratch x application
    How to use ScratchX by hand to remove swirls, scratches and water spot etchings (http://meguiarsonline.com/forums/showthread.php?t=1516) How to use ScratchX by hand to remove defects like these, Scratches Swirls Bird Dropping Etchings Water spots Scuff and Mars + + = Success! A couple of important notes to
    you want to wipe off with an MF in between each application, not just at the end.
    for #7, what i do is apply it with the foam applicator, and rub it in with the foam applicator as well. Then buff it out with an MF.
