Discoloration in Mom's Corolla
  • Discoloration in Mom's Corolla
    Hey, my mom has a white 04 Corolla and there is a spot on her trunk that is slightly discolored. I used DC #1 and Scratch-X and it reduced the appearance, but I can still see it. Right now I am working by hand and was wondering if there was anything else that I could try to fix this. I don't have a picture because I can't get it to show up. The spot is lighter and a brighter white. I know that white is a boring color and defects are not very noticeable, it will bother me until I know it is gone. Thanks
    Kevin
    well....you could try using M83 Dual action cleaner/polish by hand, or maybe using sratchX or DC1 with the PC at speed 4.5 and a foam polishing pad, can correct this defect
    just make sure that the spot you see is not a possible clear coat failure.
    if you know how to use a rotary buffer, and you are completely sure it's not a possible clear coat failure, use M80 speed glaze with a foam polishing pad at 1500RPM. if you need a little more aggressiveness, switch to M83 and buff at 1500RPM, then use M80 at 1200RPM.
    hope this helps
      It doesn't look like clearcoat failure to me, and isn't it a little soon for that? Anyway, I don't have access to a PC or a rotary and can't find M83 in stores. When I get my paypal account set up I will order it and try. Until then, are there any other suggestions?
        well....maybe the only option left would be to use DC1 or scratchX until you get out the defect....maybe 3 to 6 passes with the product might solve the problem :P and well, regarding the rotary, it all depends on how aggressive you want to go.
        let's say, an unnecessary proccess would've been using a compound or cleaner like fine, medium or heavy cut cleaner with a foam cutting pad or a wool pad.
        using a rotary buffer and a foam polishing pad with a product like speed glaze has a very light cutting action, and if you like mirror-like shine results, you'll get them and they will meet even your toughest expectatives.
        however I hope you can remove the defect using scratchX only. and if you ever get interested in learning how to buff with a rotary, I recommend you buying the meguiars video for that. It's the best thing i've ever seen for using the rotary.
          At the moment your best bet would be to keep using Scratch-X. At the DFW seminar, Mike used 5 passes to remove a defect, sometimes it take a lot of elbow grease, or "passion" to full remove a defect.
