I have a white vinyl top that has yellow spots. they are small, and when I scratch them off, it leaves a tiny yellow spot that I cannot seem to get off the vinyl. Any suggetions on how to remove the yellow "dot"? It could be from a tree or a insect, but I am uncertain as to where it originated from. The original spot has a hard top layer in texture surface and removing it leaves more of a yellow stain.
tree deposits on vinyl
Well, I think the best cleaner for you will be the #39 Vinyl and Rubber Cleaner.
#39 Heavy Duty Vinyl Cleaner
You will want to wash, maybe even clay to get any other bonded contaminants, and then use the #39. You may need a soft toothbrush or terry cloth to agitate a little.
Afterwards, follow up with a vinyl/rubber conditioner to protect it. #40 Vinyl and Rubber Cleaner/Conditioner is a good start, or there are also cleaner/conditioners in the Marine Line of products such as the Flagship Premium Vinyl and Rubber Protectant.
#40 Vinyl & Rubber Cleaner/Conditioner
Re: tree deposits on vinyl
Originally posted by truetriplex
I have a white vinyl top that has yellow spots. they are small, and when I scratch them off, it leaves a tiny yellow spot that I cannot seem to get off the vinyl. Any suggestions on how to remove the yellow "dot"? It could be from a tree or a insect, but I am uncertain as to where it originated from. The original spot has a hard top layer in texture surface and removing it leaves more of a yellow stain.
Welcome to Meguiar's Online!
These spots could be bug droppings?
The M39 Murr1525 suggested is a great dedicated vinyl cleaner, apply it and then scrub it with a soft brush like our Body Brush and then rinse off and apply a conditioner/protectant.
p.s.
I've moved this to the Detailing 101 forum.
