#83 dried on Line X
  • #83 dried on Line X
    I was using some #83 on my friends truck
    I should have masked off the line x of the truck bed but now its been a month, and after some scrubbing and washes, the #83 is white and dried up on the Line X of his bed rails
    what can i use to clean it off the Line X, i tried using all purpose cleaner and a bristle brush
    Thats odd APC will not remove it. You might want to try Gold Class Trim Detailer. That might help or you can always try a eraser from a pencil. I had some luck when I got to work and noticed I had a little splatter on the liner and tried using the eraser from the pencil I had on me. Took it right off.
      I find that Meguiars #39 Heavy Duty Vinyl cleaner usually gets the job done on normal car trim/rubber.
      -Bob
        Jarrettb,
        I have the same problem on my x-liner used #39 with a toothbrush, it worked.
        colorado
