Can any one provide a chart which will show which products can/should be applied/removed by hand and which products can/should be applied/removed with a PC or other mechanical device.
Chart for waxes
well accoding to that chart it says that #7 has no cut (Cut meter) adn it also states that its a pure polish.
I thought all polishes had to take off very little paint in order to remove fine swirls and so on. SO was I misinformed here.
#7 Pure Polish enhances the look only. It doesn't include any abrasives in it that would be used to remove fine scratches. You might say it's like a shoe polish--it makes things look better, but doesn't perform any work to remove any blemishes--where unlike a shoe polish would just mask or cover up a blemish, #7 makes darker finishes look better.
Meguiar's has a number of products like M80, M83, M82, ScratchX, and others that are a combination polish/cleaner with diminishing abrasives. For the Meguiar's products, you just need to adjust what you already know, to conform with their descriptions.
M80 is a close cousin to #7. That is, you like the look of #7? Add some abrasives for cutting, and now you got M80. =) Well sort of--not exactly, but in concept it is.
Richard
Im glad to see that things got cleared up there. thanks, but one more question, could you use #7 everytime you wax? adn note I like to wax a lot...lol, I just dont want to over use the product adn end up causing some big trouble for myself
Sure! You could use it every day if you wanted to.
Just remember to put it underneath the wax. It's a polish that enhances the depth of the paint, but as a polish, it will wash off, unless you seal it with a wax.
Also remember Polishes don't need to dry before wiping off, so apply it with a foam applicator, probably to the whole car or half the car depending on your time, then gently wipe it off.
Richard
Ya M07 is amazing stuff! I find that it is easier to use by hand than with a G100. All you have to remember is don't let it dry, and like any other megs products don't get in your eyes or swallowPatrick Yu
2003 Honda Accord
2008 Honda Accord EX-L V6
