QD and #21
  • QD and #21
    Whats everyone using to QD #21 after the weekly wash... And how often should I use a spray wax with the #21?
    My first choice is the NXT Speed Detailer, which you can probably find locally. My second choice is the Last Touch from the Detailer line. You can get it direct from Meguiars.
    I don't use Spray Wax with #21. It is not necessary. But using it once a month might be worth a try. I would go with the NXT Spray Booster Wax, since they are both pure synthetic. I'm not sure if the Quick Wax is a blend or all synthetic. But I've used the NXT Spray and it looks great!
    The #21 is so easy to wipe off you can just reapply that instead of a spray wax.
    RamAirV1
    2006 GTO Impulse Blue
