smooth surface kit question....
  • #16
    Actualy, this would be the better order:
    1. Wash
    2. Clay if needed
    3. ScratchX
    4. Cleaner/wax
    5. Wax
    6. Spray Wax etc after other washings.
    What you want to do is follow these steps:
    1. Wash
    2. Clay
    3. Clean
    4. Polish
    5. Wax
    6. Maintain
    Your order was like this:
    1. Wash
    2. Clay
    3. Clean -> Polish -> Wax
    4. Clean
    5. Wax
    6. Maintain
    You can see how you were a little out of order.
    • #17
      ok thanks.....like i said ive only waxed it like 2 times in 3 years and never clayed it so im pretty much thinkin that with those 6 steps i will be able to tell a HUGE diff.
      • #18
        hmmm so it should be like this.....
        1.wash
        2.clay
        3.scratch-x
        4.cleaner wax
        5.wax
        i also noticed that you were saying both scratch-x AND colorX....did you mean both? which one would be better???
        • #19
          Well.. lets just say I have both... They both have their place.
          ScratchX is a fairly agressive cleaner, and is the only way to try and remove medium swirls/scratches. It is also very time intensive, and your arms will fall off after the car is done.
          ColorX will not remove things as severe, but is easier to use. It is also 3-steps in one, cleaner/polish/wax.
          Remember, single step products will almost always work better than multi-step products.
          That is why I follow up a with a pure wax after ColorX, in order to get the best looks/protection from the wax.
          So you are certainly welcome to use ScratchX to take advantage of its cleaning properties, followed by either cleaner/wax, either the Cleaner/Wax or ColorX. Hopefully you wont be using ScratchX more than every so often on small areas after this first time.
          I hope that helps? Or ask some more...
          • #20
            no i think that helped alot thanks, i think im gonna do the car with scratchX cause its been so long so i think i need to do all i can for my paint since ive been neglecting it for so long.
            • #21
              It might be worth noting we were suggesting to replace the Cleaner/Wax (in the red bottle) with ColorX. Not replace ScratchX with ColorX, or at least I was. Just in case there was any confusion along the way.
              • #22
                for some reason im alittle confused with that last post.....can you put the FINAL DRAFT of steps on here cause i just got off the short bus sorry.....LOL
                • #23
                  And here i thought I was clearing things up... oh well...
                  1. Wash
                  2. Clay as needed
                  3. ScratchX
                  4. Cleaner/Wax or ColorX - Pick one, no big deal which. Might as well use the small sample up first.
                  5. Wax
                  6. Maintain
                  • #24
                    well you pretty much did but i read it wrong and noticed after i posted that so once again thanks....i think this might be my WHOLE sat....o well i think the results will be worth it.
