Airport parking
  • Airport parking
    My car is often at the airport more than at home. It is left outside uncovered. I know the exhaust from aircraft is bad for the paint. What is the best methos for protecting the paint? I have applied two coats of NXT wax, is there such a thing as waxing to much? Should I just wash the car more often? Your suggestions are appreciated
    Well, you can always try parking undercover if it is available.
    You can never wax too much, and that will be about the best you can do, unless you would want to try a car cover during your longer trips.
    Just be sure you have washed your car well before waxing, as you wouldnt want to drag any dirt around.
      I would have to agree, looking into getting a car cover might be the best thing for you. Make sure that you use the Quik Detailer or a mist and wipe product to remove any light contaiments on your vehicle to prevent and light scratches when putting on or taking off the car cover.
      As far as using a wax, all you'll need is two coats of NXT Tech Wax or a Meguiar's Wax of your choice.
      Shane Lariba
      800-854-8073 ext 138
      Shane Lariba
      Surface Car Specialist
      1-800-854-8073 ext 138
        Thanks!!
