Auto Glass cleaning -- HELP ME
  • #46
    Re: Auto Glass cleaning -- HELP ME
    Not to sound short, but otherwise it is a matter of technique to get it right the first time.
    I have found that RainX seems to get rid of any smears on the outside when removed properly (not leaving its own residue), and if you keep after the inside so no film builds up heavy, a light mist on the towel and then wipe is all you really need (can flip towel over for a dry wipe). Just being sure to wipe over all the glass and not miss a spot, and the glass cleaner wont leave its own streaks.
    If there is a heavy film, you may need to clean a couple times, so that your final time is real light mist again.
    I use the Nxt Glass Cleaner at the moment, and like a smaller, short nap MF towel, like the Vroom ones. Doing things like claying the outside if needed can give a better surface to work on.
    And at least if you can get out of the direct sun, or hot sun to work. Dont like damp conditions either.
