Need some help
  • Need some help
    Hi I just finish painting my bike and color sanding now I don't now what products to use for a realy nice finish, some help please.
    Cleaning/Removing Sanding Marks:
    After you've sanded and dried off the surface, you'll need to use Compound Power Cleaner (#84) with a Wool Pad on a Rotary Buffer. Follow #84 with #83, Dual Action Cleaner/Polish with a Burgundy, Foam Cutting Pad. Follow #83 with #9, Swirl Remover, with a Yellow Foam Polishing Pad. With all of these products you want to wipe off the excess before it dries with a 100% Cotton, Terry Cloth towel.
    Finally, you'll want to finish the job off with a wax of some sort. Depending on the wax, you could either use the Rotary Buffer to apply it or an Orbital, or a Dual Action or you could always do it by hand. If you use a machine, use a Tan, Foam Finishing Pad or a Terry Cloth Bonnet (Orbital Buffer only). After you apply it, making sure to do a nice thin, even coat over the vehicle, allow the product to dry for about ten to fifteen minutes and after that time you'll notice that the product has dried to a haze. When you reach this point, wipe off the residue again by hand with a 100% Cotton, Terry Cloth towel.
    Using a Rotary Buffer:
    If you have never used a Rotary Buffer, I would suggest getting some panels that you can practice with before you move to your vehicle. The Rotary Buffer is a high speed machine that is easy to use incorrectly and cause damage to paint with. If you don't keep it flat on the surface and moving at all times, you can end up with swirl marks or even burns in your paint. When you use it, move in a back and forth manner, overlapping about 50% with every pass and do this without applying any pressure. Just let the machine glide. Make a couple of passes in this manner and you will be set.
    Hope this helps
    Tim Larson
    Meguiar’s
    Customer Care Rep
    1-800-854-8073 ext. 169
    Tim Larson
    Meguiars Customer Care Rep
    Tlarson@meguiars.com
      Re: Need some help
      Originally posted by madpitbull
      Hi I just finish painting my bike and color sanding now I don't now what products to use for a really nice finish, some help please.
      Hi madpitbull,
      Welcome to Meguiar's Online!
      Quik question, have you ever used a rotary buffer to remove sanding marks before?
      Also, when you say "bike", you do mean motorcycle don't you? Are you working primarily on the fenders and tank? Just want to make sure as we've had people sanding on bicycles!
      What kind of paint did you use? Is it a basecoat/clearcoat system? If so how much clear did you apply?
      When removing sanding marks out of fresh paint you always want to,
      "Always use the least aggressive product to get the job done"
      This means it's nice to have more than one compound on hand and at least one or two cleaner/polishes as well as a few pads, such as a wool cutting pad, a foam cutting pad and a polishing pad.
      I have something posted on this the process I'll try to find it.
      As far as waxing fresh paint goes, most paint companies and painters recommend you wait for around 30 days before sealing the paint.
        Here's a rather lengthy reply to a question related to removing sanding marks from this thread,
        Switching from 3M to Meguiar's - Rotary Buffer Questions?
        I would suggest clicking on the above link and reading the entire thread as that way everything I'm copying and pasting below will make more sense. Towards the end of this reply you'll see product, pad and speed settings as well as finishing suggestions.
        Here goes... copied and pasted from above thread, which can be found in the Hot Topics Forum
        (Everything is in the Hot Topic forum!)
        >>> Begin Copy and Paste <<<
        Originally posted by Solus
        Hi there, well its me again guys, look i been using 3M products and they work good, i just use the Perfect-It II Rubbing compound and the swirl remover, but now i am interest on using Meguiar's and i found Fine Cut , Medium Cut and Heavy cut cleaners, which i don't know why i think are similar as Dual action cleaner/polish, compound power cleaner, and diamond cut compound.
        Hi Solus,
        The questions is what is the difference between them, i mean i know fine is light compound and heavy is aggressive as dual action is light compound and diamond is the aggressive one, but why there are like 2 light compounds and 2 abrasives, is that because of different paints? like the ones of th body shops that sometimes are harder cuz of too much hardness and cheap paint, and that the stock ones are soft? Or is just preference or what would be a difference?
        The primary difference is they type of diminishing abrasive they use, at least that's the difference most people would notice when using them. All of these products, M01, M02, M04, M85, M84, M83, M82, M80, can be used on either clearcoated finishes, or non-clearcoated finishes. The 80's series are more modern technology based upon Meguiar's experience formulating products used at the OEM level. I would also like to add that the formula's for the Traditional Mirror Glaze Products, M02, M04, have also been updated when technology allows. I'm not sure about M01 Medium Cut Cleaner.
        Either way, both groups of products work well when used according to directions on the label and which one works best for you will be based upon your personal preferences.
        I'm sure a lot of you guys have used these products would you share with me some of your experience with them? plus comments.
        I think Travis has contributed a lot to this thread already, thank you Travis!
        Sometimes you have to work on the Sun because theres no shade, also many compounds dry too fast cuz of the hot surface and evaporate leaving all sticky the compound on the paint, i don't know if this happens with these compounds.
        There are no compounds, paint cleaners, cleaner/polishes or pure polishes manufactured by Meguiar's specifically formulated for use in direct sunlight on automotive paints. The sun, or more specifically, the heat created by sunlight will increase surface temperature of the finish and make any product more difficult to work with and affect the performance of the product dramatically. Meguiar's always recommends working on a cool surface in the shade. We understand that when doing mobile detailing work, this isn't always possible, one solution is to do what Joe of
        Superior Shine Mobil Auto Detailing
        does and that is to use a portable canopy when working in direct sunlight.
        You can check out Joe's most excellent before and after write-up on how he removed the swirls in the finish of the black BMW using Meguiar's compounds, polishes and waxes in the below thread. (If the below makeover doesn't knock your socks off, nothing will!)
        BMW 745il Extreme Make-Over
        Also do they hide swirl marks?
        Meguiar's compounds, paint cleaners and cleaner/polishes all use Meguiar's Diminishing Abrasive Technology. When used correctly, the diminishing abrasive technology Meguiar's has pioneered since 1901 and continues to improve today, will do two things,
        • 1. Remove the below surface defects, swirls, sanding marks, etchings, oxidation, etc.
          2. Remove their own marks as they reduce in size and polish out
        like i like to wash the car with a sponge after compound and polish just with water to remove all the dust left by compounding and polishing, and then after that i glaze it and protect it with a pure wax or polymer.(depending on the color)
        I been detailing for 2 years started with a rotary buffer burning some paints :P but well i have worked on 2 detail shops and a mobile detail, and i got some experience from there, also by doing some side jobs. I don't burn paint anymore
        I would recommend reading the below two threads in the Hot Topics because they discuss in detail working what can and what cannot be done with a rotary buffer as far as creating a swirl free finish.
        Need HELP! - How to avoid holograms?
        How to avoid swirls and holograms?
        In the end, in order to guarantee a completely swirl free finish on a dark colored paint in bright lights, you're going to need to re-polish each panel either by hand or with a dual action polisher to insure any remaining minor swirls induced by the direct drive circular contact between your pad of choice on a rotary buffer and the paint are completely removed. That, or use a coating or two of wax to insure any remaining holograms or swirls are eliminated.
        Read the above two threads as there is a lot of good information in them that would not be efficient to try to re-post into this thread.
        Here is one example of a selection of products you can start out with when switching over to Meguiar's from 3M. This is not you're only option, but I'm trying to keep it simple with only a few products for you to experiment with.
        The M84 Compound Power Cleaner is an easy product to use with a lot of play time. It is formulated to be used with foam pads, not wool pads, so you can avoid using wool and thus avoid instilling wool fiber swirls.
        The M80 Speed Glaze is a light cleaner/polish that will remove fine swirls with our W-8006 polishing pad. The key to making this product remove any leftover swirls from the M84 Compound Power Cleaner is to make sure you buff the M84 completely so that you have broken all of the diminishing abrasives down completely. This is the trick to not leaving behind any deeper swirls with Meguiar's compounds. (Don't buff to a dry buff however).
        The M80 Speed Glaze is also easy to work with, offers a lot of play time, and easy to wipe off. You can then also use it with the dual action polisher to insure there are no remaining swirls. M80 Speed Glaze produces a very, very, clear and glossy finish, perfect for applying your LSP to.
        Again, the below recommendations are not the only products or method of tackling every car, but it is a system that will work on most cars that you will come across and 99.9% of the time, it will produce professional results you can be proud of and your customers will love you for and recommend you to their friends.
        It's also the system I used to remove the swirls on this clearcoated Corvette and restore a swirl-free, crystal clear finish.
        1999 Corvette - Remove Swirls and Scratches
        First Step Products and Process
        Rotary Buffer for removing serious below surface defects,
        SOFTBUFFâ„¢ Cutting Pad
        Second Step Products and Process
        Rotary buffer for removing any residual swirls or haze left by the first step process.
        Speed Glaze
        Soft Buff® Foam Polishing Pads
        Third Step Products and Process
        Dual Action Polisher to insure a completely swirl free finish in direct sun or bright lights.
        Electric Dual Action Polisher
        Speed Glaze
        At this step, use the above same products that you used with a rotary buffer in your second step process, only now substitute a different machine to apply them with. For this step, use a dual action polisher to re-polish each panel using the oscillating action of this type of machine to polish and remove any remaining swirls left by the rotary buffer to insure a completely swirl-free finish.
        Last Step Products and Process
        By hand or using a dual action polisher to apply your choice of wax, also known as your L.S.P., Last Step Product, this is the last product you apply and remove before standing back and saying to yourself, it is finished. Then, turn the car back over to the excited owner!
        SOFTBUFFâ„¢ Finishing Pad
        Meguiar's LSP's
        Here are a few options for last step products if you've performed a multiple-step process as outlined above.
        NXT Generation„¢ Tech Wax
        NXT Generation Tech Wax Paste
        Gold Class Clear Coat Car Wax
        Deep Crystal System Carnauba Wax
        Hi-Tech Yellow Wax
        Synthetic Sealant
        Polymer Sealant
        This reply took a little while to write, I hope it helps...
