nxt spray wax
  • nxt spray wax
    how much window of time does nxt spray wax [ booster wax ] require to set ?
    would it be more beneficial to apply nxt spray wax in two layers seperated by some time frame ?
    thanks
    Nxt Spray Wax should not be confused with a regular coat of wax. Sort of like a quick detailer, it is mostly for looks, so one coat is fine.
    If you have applied it properly, the first places you sprayed it should be about set by the time you finish applying the last spray.
    How to Get Great Results Using Meguiar's Spray Waxes
