Combination
  • Combination
    I was wondering if you can combine differant megs products together in your cleaning regime, as i already have the DC paint cleaner and i was wondering if i cant combine that with a clay kit, also can i use NXT products with the DC range?
    Thank you
    Detailing is a passion NOT a chore
    Re: Combination
    Thank you
    Yes, you are fine with using the DC Paint Cleaner "after" the clay kit. I have done this several times and it's fine. Mike always states that all Meguiar's products are compatible and I find this to be true.
    As far as you comment about using the NXT Products with the DC Range, you might want to be a little more specific as far as which product in each line you are referring to. I am sure you will have no compatability issues but I am sue if you were a little more specific you will not only get your question answered but will get some commentary from the others about your thoughts that you have not considered yet.
    Jeff Smith
      Jeff!!!! your back!!!
      back
      Patrick Yu
      2003 Honda Accord
      2008 Honda Accord EX-L V6
        Re: Re: Combination
        Basicly any NXT product with the DC range
          Re: Re: Re: Combination
          You'll be fine. I don't want to scare you into thinking that you'll have compatability issues by using these products together. The only reason I recommended your being a little more specific is because I know alot of the folks here have tried all sorts of combinations and might be able to tell you what you might be able to expect from any particular combination.
          I have tried all sorts of combinations and with Meguiar's stuff I can't say I have ever stumbled into any bad combinaton at all. Everything yeilds great results for me. But I do find certain combinations tend to yeild results that are more to my liking than others. All a matter of taste there though.
          Anway, good luck with the stuff. Hope you are as satisfied as I.
          Jeff Smith
            Hi fellow South Aussie
            i can assure you that you will have no issues with using the NXT products with the DC range. Where in SA are you and where do you buy your meguiars from?
            I'm doing a purchase from usa soon if you'd like to split the freight?
            All people give pleasure : some when they arrive, others when they leave
              Im from whyalla, and i get my megs products from autopro
