How to clean up bonnets, 8006, 9006 pads?
  • How to clean up bonnets, 8006, 9006 pads?
    I just used my DA for the first time today and love it! How do i go about cleaning the 8006 pad and bonnet (to remove M080) ?
    Thanks,
    Mark
    Hey,
    Glad to hear you are enjoying your G100! They are a fantastic machine!!!
    Here is Meguiar's official recommendation regarding the cleaning of the foam pads:
    From Mike Phillips:
    How to clean Meguiar's foam buffing pads
    Meguiar's does not recommend washing any of our foam buffing pads either by hand or by machine.
    Meguiar's recommends,
    • * Tapping them when they are dry to knock loose any dried product
      * Holding an absorbent terry cloth towel into them when they are wet to absorb excess product out of them.
      * Storing them wet in a zip-lock bag for re-use later
      * Turning the polisher on while holding the foam pad against an absorbent cotton terry cloth towel to transfer excess product into the towel
      * Brushing dried, excess product from the face of the pad using a nylon bristle brush, like a toothbrush for example.
    Here is a link to info regarding the cleaning of the pads...
    How to clean Meguiar's foam buffing pads (http://meguiarsonline.com/forums/showthread.php?t=3598) Meguiar's does not recommend washing any of our foam buffing pads either by hand or by machine. Meguiar's recommends, * Tapping them when they are dry to knock loose any dried product * Holding an absorbent terry cloth
    I hope this helps!
      when i'm finished with the pads, i let them soak in a a mixture of warm water and dawn. i then squeeze the excess water out and let them dry on top of my grit guard.
        I just finished washing one of my my Ultimate Bonnets. I used a MF-specific detergent, hot water, regular cycle, multiple rinses with distilled white vinegar in the final rinse, machine dry on low temp. Been washing/drying them this way for ages and they're all still like new. FWIW I was cleaning it after using it to buff off #16.
        After using #80, I hand wash my Meguiar's pads with Dawn and hot water and then twist/blot as dry as possible, letting them air dry the rest of the way. Hasn't affected the velcro adhesive (yet) or caused any other problems. #80 washes out pretty easily, don't worry about a little remaining staining from the green/brown pigments.
        Practical Perfectionist
          I do the same, only had a velcro backing fail once a long time ago and none since. I have found they dry a little faster if you stand them up on end.
          Brandon
          2007 Black Chevy Avalanche
          My Albums: Avalanche
