50/50 product?
  • 50/50 product?
    Hi everyone,
    I've seen here in a couple of topics the use of 50/50 water-alcahol. For what can I use this? Between the polish & wax.?For anti swirls or what?
    Kind regards Bert
    From what I've seen, people use it to strip the paint surface of wax/polish to get a better look at swirls/scratches.
    -Dennis/FromThisSoil
    If anyone is in need of a company logo or flier design, don't hesitate to ask for help.
    I can accommodate any budget.
    To see a few samples of my work just PM me.
      When using something like a paint cleaner, or cleaner/polish to remove swirls, some of the product can tend to fill in swirls, so it looks like they are gone.
      If you are not sure if you have remoed swirls completly, then using the 50/50 mixutre after the cleaner will remove any of this filler, so you can see for sure that you removed them, or even didnt add any more.
      This is good at first espeacialy, when you are learning to use a product. After a while, you will know when you have worked the product in long enough, properly, etc to remove everything.
        ah ok, i get it
        Are you using alcahol witch you can buy for medics?
        Is these good?
        Kind regards Bert
          You need isopropyl alcohol. Don't worry, common item in any pharmacy/drug store.
