2 Coat ?
  • 2 Coat ?
    What does it mean apply 2 coat. Do we apply 1 coat of wx lets say NXT and then remove it and then re apply another one?
    its best to wait 12 hours between coats
    NXT Tech Wax Cure Time
    Patrick Yu
    2003 Honda Accord
    2008 Honda Accord EX-L V6
      So apply 1 coat of NXT, remove it , wait 12 hrs and then re apply another coat?
        wipe it then leave it alone or else you will disrupt the polymers
        Patrick Yu
        2003 Honda Accord
          Hey adcha1
          Welcome to Meguiar's Online!
          In the ideal world, it is recommended that you allow at least overnight before adding the second coat of product as this will allow the product to set up properly. However, sometimes with time constraints, you may have to apply it sooner.
          Tim Lingor's Product Reviews
            *making an edit here
            Place first coat of wax down. Wipe the finish clean with a microfiber cloth. Repeat after letting the wax set up over a number of hours.
            Proud owner of the finest looking car in the parking lot.
            Switch to Linux. Use energy efficient lightbulbs and appliances. Keep your car well maintained and drive easy to save gas. Eat less fast food. Call your mother and tell her you love her. Try flying a kite. Read a wikipedia article daily. Use Meguiar's.
              Well.. let me try and lay it out...
              1. Wash
              2. Clay
              3. Clean
              4. Polish
              5. Wax - Spread first coat of wax. Then after it has hazed over, remove with a MF cloth.
              6. Wax - Once previous coat is removed, wait as long as possible. 12 hours is best, but try for at least 20 minutes. The goal is to give as much setup time as possible, before applying the next layer.
                Originally posted by LiquidBlack
                This means: no, dont remove the first coat. You just layer the second coat over the first coat after the first has set up over a number of hours.
                No. Just to clarify...that means that after you have applied and removed the first coat, that you allow the car to sit overnight before applying and removing the second coat.
                I hope that clarifies things a little better,
                  Oops, seems I kinda got my message tied up in language. What I thought he meant was to put a layer of wax on, then strip it all off (by dawn, clay, etc) then rewax.
                    Thanks guys
                      Hey adcha1
                      You are very welcome! If you have any other questions, do not hesitate to ask them!!
                      Cheers!
                        So then would you be wise to let the second coat sit for say about 12 hours as well to settle before you use any other products on the surface such as the QD?? Or are you able to do anything you want pretty much after the second coat is applied as it is not required to "set" as the first coat was?
                        Trent W.
                        2002 Ford F-150 SuperCrew FX4
                        2002 Chevrolet Tahoe LS
                          It is still a good idea to let the 2nd coat sit as long as possible.
