In between waxes, wax as u dry usage
  • In between waxes, wax as u dry usage
    I have a couple bottle of Eagle one - wax as u dry for xmas. I was wondering if its ok to use these products while im drying the car in between the months im not waxing the car ?
    Does it do more harm than good ?
    Re: In between waxes, wax as u dry usage
    I have never used the "wax as you dry" but I am sure it will work just fine. You might compare it to a spray wax... good for in between traditional wax but not a substitute for a traditional wax.
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
      i have recieved a few eagle one products for xmas as well the wheel +tire cleaner isnt all that bad i dunno about the wax . they have a unique formula as you can see every spec of brake dust lift of ur rims/tires its different
      "A musclecar, by definition, is a powerful and sporty vehicle that must be able to spin its tires at will. The Firebird Trans Am is capable of laying down twin black streaks of rubber several hundred feet long. We wanted to be sure it could, so we did it a half dozen times in the name of automotive science." - Motor Trend
        wax as u dry is an onkay product at best
        although it does smell good
        you should be okay for in between waxings where you just wax
        Patrick Yu
        2003 Honda Accord
        2008 Honda Accord EX-L V6
          Before I was turned on to Megs, I used Eagle One Wax as you dry religiously. I only waxed my vehicle about once a year though. At the time I believed I acheived great results with the Eagle One. However I could immediately see the difference when I begin to use Megs products.
          Oh yeah, I applied it to my wet vehicle and dryed with a natural chamois and I pretty much destroyed the chamois. I was able to use it multiple times with the Eagle One but never for anything else.
          So it did work fine for me, at the time, but I have been much more impressed by my results with Megs. As far as doing harm, I don't believe the Eagle one harmed my vehicle at all, it appeared that it did protect my vehicle, because once I started with Megs I had a much easier time getting a geat finish than I did with my vehicles that did not get the Eagle One.
          Hope this feedback helps.
            There is no way to be sure of compatibility between different companies products. Obviously, Meguiars only worries about being compatible with Meguiars.
            That said, Meguiars seems to work well with most other companies products. Even if the Eagle One isnt compatible, or doesnt give the results you want, your car isnt going to explode.
            Just give it a shot on a section, and see how it turns out. Keep us posted
