Which order???
  • Which order???
    I am using #20 sealant and NXT wax, or at least thats my plan (unless someone has reasons I shouldn't) but not sure in what order should they be applied? NXT--20 or 20--NXT or don't use the two together. Also if anyone has a better combo please let me know, Im open to all suggestions.
    Re: Which order???
    I think #20 is said to have more cleaners in it so I would, and have, put NXT over #20.
    I was happy with the results. "BUT" be forewarned that there is only a very slight difference in the appearance after putting the NXT over the #20. So slight that you will likely be the only person that would ever be able to tell the difference and I would not bet a paycheck on even you being able ot tell. At the time I did it, I could not tell either. I am sure a trained eye could but not mine.
    But I went ahead and did it as I wanted a good protection layer for the upcoming winter. I did this on white paint and was happy enough with the results to do it again.
    I recommend 2 coats of #20 topped with 1 coat of NXT. Then follow up applications of NXT as needed or even the NXT Spray Wax.
    Jeff Smith
      If you have already purchased, then I would use #20 first, then Nxt.
      If not, then Nxt followed by #21 might be more usefull, if you dont need the cleaning.
      But as was mentioned, I think you will have a hard time telling between #20, #21, and Nxt.
