Is M66 will remove pervious rotary hologram or I should go first with M205 first.
Quick Detailer M66
Re: Quick Detailer M66
It depends on how severe the rotary holograms are and also which machine you are applying the M66 Quick Detailer with. Typically holograms inflicted from a foam pad on a rotary are more difficult to remove than ones inflicted from a wool pad.Nick Winn
Originally posted by Nicholas Winn View PostIt depends on how severe the rotary holograms are and also which machine you are applying the M66 Quick Detailer with. Typically holograms inflicted from a foam pad on a rotary are more difficult to remove than ones inflicted from a wool pad.
I'm planing to use Flex rotary with finishing or polishing pad with M66. Is that sounds good or you prefer other approach.
Originally posted by mohebmhanna View PostI'm planing to use Flex rotary with finishing or polishing pad with M66. Is that sounds good or you prefer other approach.Nick Winn
