I usually have no issue with defect removal on metal painted surfaces but as we all know many vehicles have a front end that is made of plastic. Especially around the front bumper, headlights etc. It's that painted plastic that I can never seem to get as clear as the metal surfaces. I typically use the same pads and products I am using on the metal surfaces. Am I doing something wrong? Is there a different technique/product for the painted plastic? Thank you for helping.
Frustrated With Plastic Nose Clip
Re: Frustrated With Plastic Nose Clip
Originally posted by Selectchoice View PostWhat products/machines/pads are you using currently?Nick Winn
Originally posted by Nicholas Winn View PostWe would also ask what step are you specifically having an issue with? Removing all defects, getting the paint to finish haze free etc.
Well, you know me, I say go more aggressive As I've read here from Mr. Stoops, the plastic can potentially heat up too much with excessive machine compounding, and so more cut will be better, and with shorter time and/or less speed and/or pressure, will further avoid harming the paint/plastic. If UC and D300 aren't cutting, especially using the Xtra Cut disc (been there, done that), I suggest the wonder-compound M101, or perhaps M100, on the regular Cutting MF to start, and back off the speed/pressure. Another option is wet-sanding instead (assume the usual disclaimers and precautions as that's a whole other discussion), then follow with D300.Non-Garaged Daily Driver, DAMF System + M101, Carnauba Finish Enthusiast
4-Step | Zen Detailing | Undercarriage | DAMF Upgrade | First Correction | Gallery
