what causes this?
Re: what causes this?
Haven't used those on plastic trim, as I use Ultimate Black (UB). Looks like your plastic trim is dried out, so to speak, but only in certain areas. UB will soak in very well and evenly, and then I use UWWA and/or QW on top to kinda "seal" the oils from running/smearing.Non-Garaged Daily Driver, DAMF System + M101, Carnauba Finish Enthusiast
4-Step | Zen Detailing | Undercarriage | DAMF Upgrade | First Correction | Gallery
We are not familiar with the product you are using also but are you wiping the product with a towel after application? Is this required? If not we would try to get your application to a point where you can just apply the product with an applicator pad, work it in, and not touch it after that point. This type of application is recommended for best results with a product like our Ultimate Black Plastic Restorer gel (G15812). Apply a small amount with a soft foam applicator pad like our X3070, thoroughly work the product into the surface and no wiping with a towel should be needed. This generally leaves the most "even" appearance.Nick Winn
