Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Kerosene for car wash!?!?!!???
    Registered Member MI DOG's Avatar
    Jan 2007
    Meguiar's Center - Jakarta - Indonesia
    56
    Have you ever heard of using kerosene as additive for your car wash soap?My friend used this method to wash his car. he said mix 100cc kerosene to water and car wash soap (cheap one) and he said the result were good.. and said he doesnt need to polish his car
    in long term,does kerosene will have bad effect for paint or clear coat?
    Registered Member 9C1 MAN's Avatar
    Apr 2007
    106
    12
    Re: Kerosene for car wash!?!?!!???
    ER... YES I WOULD THINK SO; A LITTLE LIKE PUTING GAS ON YOUR CAR; I WOULD STICK TO THE PROPER CAR WASH SOAP. MYSELF I LIKE NXT OR GOLD CLASS; BOTH GREAT PRODUCTS. JUST MY 2 CENTS WORTH.
    Detailing BoZo jfelbab's Avatar
    Apr 2004
    Cape Coral, FL
    1,462
    28
    Quote Originally Posted by MI DOG View Post
    I knew an old codger who owned and ran a limo service and that is what he used on his limos. He claimed that it shines as good as any wax, water beads as good as any wax and that it would get into the tiniest crevices to protect better than wax. His limo's looked awesome. I never tested his theory myself but his vehicles were stunning, no swirls, no rust and glossy as all hell.
    56
    24,797
    517
    Worked as a Roughneck on a Oil Drilling Rig one time and we added kerosene to all our wash water for maintaining all the mud pumps on the drilling site. Kept them clean and shiny and seem to help keep everything from rusting. Also made cleaning off mud from gasket blowouts off the pumps fast so you could take the pump apart and install a new gasket. (Had to be able to see what you're doing).
    Roughnecks changing drill tube - see the mud everywhere.
    In case you didn't know, when you're drilling you use a pre-mixed mud as a lubricant for the drill bit and pump the stuff continually down the shaft of the drill tubes. So you make a lot of mud, the stuff comes in 50 pound bags by the truck load and one of the jobs on a drill site is to simply cut the bags open and add fresh mud mix to water to maintain a mud supply.
    Don't know if it will hurt anything when mixed with water and then rinsed off your car but remember you car is made with a lot of different materials besides just the clear coat paint. Meguiar's would never recommend this procedure and instead would recommend using a car wash formulated specifically for car washing.
    Registered Member kenwarthen's Avatar
    Oct 2006
    38
    12
    My father-in-law was a chauffeur for the Guggenheim family. He has told me many stories of hanging out with the chauffeurs of other wealthy families. He said many of the drivers would dip a cotton cloth rag into kerosene to wipe down the limos while they waited. He swears it made the cars, most of which were black lacquer, look gorgeous. I'm not sure how it would react with the more complex paint chemistry used on today's cars.
    56
    24,797
    517
    Single stage lacquer is a completely different than a modern clear coat, it's a lot more porous too and this enables products to penetrate into it and if it's the right product it will look great when you're done.
    This car had a single stage black lacquer finish.
    At this point, don't think we would put any kerosene on the paint.
    Jan 2007
    56
    So this method (myth maybe) approved or busted?hehehe.. anyone knows side effect off using this method?for mine,i'll never do this method. what i know kerosene have the same function to remove tar. is it right?
    Trabuco Canyon, CA
    21,318
    1135
    I have no doubt that this method will leave a cars paint looking very glossy indeed.
    Ah, but therein lies the rub. Shine is one thing, but protection is something else. We all know that a product like #7 Show Car Glaze is a proven product, designed specifically for car finishes, that adds great beauty and depth to the color. But it doesn't protect worth a darn and washes off pretty easily.
    Shine and protection do not necessarily go hand in hand.
    The Rainmaker
    Oct 2005
    Ankeny, Iowa
    444
    23
    The use of Kerosene for cleaning lots of thing, including cars is something that has been around for years.
    An uncle of mine did just what your friend suggested, add some kerosene to the wash water. I'm sure he didn't bother to measure. His vehicles always looked good, but I personally think it is not a good idea.
    The only time I have use kerosene on a vehicle was when I got into a freshly resurfaced road that absolutely coated the lower portions of an Astro van. I washed those areas with straight kerosene to remove the tar/oil, then rewashed the whole vehicle with a car wash soap. I also rewaxed the areas where I had used the kerosene. I thought the kerosene had not been kind to the wax that was on there previously.
    Charles
    The Rainmaker
    Registered Member Whelan's Avatar
    Aug 2006
    Milford
    183
    I use Kerosene when I got camping to light my lamps. IMO if its used as a fuel, not for putting on the car.
    I could imagine people with their older Ford Taurus FFV's pulling up to the Kerosene pump and just shooting it all over the car, lolololol
  1. Quick Easy Wash or any Meg's car wash soap?
    By Tecumseh TJ in forum Detailing 101
    Last Post: Oct 26th, 2008, 07:19 AM
  2. Gold Class Cash Wash or #62 Car Wash
    By anthonyd in forum Professional Line - Mirror Glaze & Detailer Line Product Discussion
    Last Post: Jun 16th, 2008, 01:36 PM
  3. Kerosene
    By gasti_ako in forum Detailing 101
    Last Post: Jun 16th, 2008, 04:53 AM
  4. How to judge a local (self wash) car wash?
    By rqk in forum Detailing 101
    Last Post: Dec 4th, 2006, 09:49 PM
  5. Meguiars Car wash for bucket free wash?
    By ktlimq in forum Detailing 101
    Last Post: Apr 9th, 2005, 02:40 AM
