After removing the pure polish, the finish is now perfectly prepared for an application of protective wax. For this demonstration we chose to apply the brand new NXT Generation Tech Wax Paste.
A pre-softened wax like Meguiar's Meguiar's Cleaner/Wax can be scooped out of the can and worked in to the paint because of the type of wax it is and it's consistency.
A wax like the NXT Tech Wax Paste however should not be scooped out, but instead, take your applicator pad, (round pads work best), and briskly spin it on top of the wax in a circular motion. The small amount of agitation and friction will tend to liquefy the wax so that it will saturate into your applicator pad. Once this has happened, you're ready to apply the wax to the surface. When starting out with a brand new can of wax you usually have to break the can in, after the initial removal of wax it will become easier to spin your pad and liquefy the wax.
Spread the wax out over the surface using gentle, overlapping motions working the wax thoroughly into the paint.
