leaking master cylinder question
  • leaking master cylinder question
    the leaking is coming from where the brake lines connect to the master cylinder, it is not happening on all 4 connections, just the two on the bottom of the master cylinder, i had the connections checked if they were tight and they were, my question is is the leak coming from the brake line connection or inside the master cylinder where the break line connects to it?
    Re: leaking master cylinder question
    you probably really wont know till you replace something, i would just go ahead and replace the master cylinder, its not to expensive, and that should give you your answer.
      i am replacing it on friday
        Good Luck
