what to expect with a rear sway bar?
  • new2detailing
    replied
    Re: what to expect with a rear sway bar?
    The size is the actual diameter of the sway bar. The larger the diameter that greater the ability of the sway bar to counteract forces applied to it. The rear sway bar will allow the rear end to stay planted on tight turns (as compared to having the inside wheel lift on a turn ). You will feel this more on a track than on a street driving normally.
  • SX4DUDE2013
    started a topic what to expect with a rear sway bar?
    So i like adding new stuff to my car. I got H&R springs over the summer and that helped the handeling a little bit. It was a one inch drop. My car (2008 Suzuki SX4 hatchback) has no rear sway bar from the factory. I just ordered a 22mm thick rear sway bar. What can I expect and what does the size mean? like 22mm vs 20mm vs 17mm???
