Creating a watermark on pictures...
  • Creating a watermark on pictures...
    Okay, now that I have Photoshop, one thing I want to do is creat a watermark for my pictures I post online. Now, I know how to do this with text, but I want to do it with my company logo.
    Kind of like what Todd did with his logo here(hope you don't mind Todd)...
    My question is, how do I do this? I don't want the color of the logo, only the outline, then create it into a watermark.
    Also, once this is completeld, how can I make it accessable so I only have to make a couple of clicks to import it into a picture?
    Thanks,
    2008 Meguiar's Batmobile Team
    2008 Meguiar's/Ford SEMA Team
    2009 Meguiar's/Ford SEMA Team
    2010 Meguiar's/Ford SEMA Team
    Re: Creating a watermark on pictures...
    Below is a gif, it should have no white background
    just creat a new layer in photoshop on the desire picture
    and put fill and opacity to 60%
    below is jpeg, it has white back ground
    so it will become this...
    hope this help
      i think you should just download the gif one,
      and then use W in photoshop for majic wand tool
      right click select inverse
      and the copy the image and paste it on the new layer for your photo
        How did you do this? I am at work at the moment, and have my laptop with me. I can not connect my laptop to the internet, and therefore can not download that image.
        How did you transform my original logo to the colorless logo?
          you open both your photo and that gif file in Photoshop
          and the photo file you create a new layer
          go back to the gif logo picture
          use W in photoshop for magic wand tool
          in the new layer of the photo you paste the logo
          set that new layer fill and opacity option to 60%
          ohoh, btw nick
          i have a question on http://www.meguiarsonline.com/forums...4&postcount=22
          do you think you can read my question and see if you can give me a suggestion or knowledge? thanks
            LOL i didn't quite answer your question,
            you just use magic wand, delete the white background,
            next you right click select inverse
            then you change the color to black and white option...
            that is it...
              I guess I'm just not getting it. Can't make this work with your instructions
              It's doing nothing that you say it should in your step by step
                Here's another way to do it.
                  which part is not working?
                  you have to make sure the layer is not lock as well...
                  because sometime when they are lock, you cannot do anything
                  just duplicate the layer and delete the lock layer,
                  it should do the magic work.
                  and thanks for replying my question.
                  so worst case, i can wash it and apply a second coat after a day?
                  would this actually be better than waxing after 20 min?
                    Yes, worst case, just rewash the vehicle again. And always let the 1st coat cure for about 8 or more hours(some say 24 hours) before moving on to the 2nd coat.
                      but which part is not work?
                      i really want to help!!
                        I don't know. Guess I'm just not getting it I am brand new to PS, and don't know very much about it at all.
                        When I convert the image to B&W, then use the wand, I either get the white background when I bring the logo over to the picture, or I just get the outline of the logo only. Just not making much sense to me. Also, I can't seen to get rid of the white background at all
                          Baby step! Treat me like you'd teach a 5 year old
                            select inverse is the trick
                            when you remove the white background,
                            you go to those gray and white squares and use magic wand to click
                            then on those gray and white squares you do a right click
                            then there is an option called "select inverse"
                            after that you will have the doted line around your logo
                            and that should be the whole logo.
                              wait i will make some photo steps
