Hybrid ceramic wax
  • Hybrid ceramic wax
    I currently use ultimate liquid wax. I plan on trying and using hcw over this. I was told that if I choose to reapply ultimate liquid wax down the road I will have to remove the hcw by using a compound. Will no future wax or sealant stick to this ceramic wax?? Is it better to let the coating wear off?? Can
    Re: Hybrid ceramic wax
    Well, your wax wont slide off and end up on the floor.... but might not get the real durability/length you would if it was bonded to paint.
    I'm looking at the HCW like a spray wax while drying after regular washes, and then doing a full detail with the polish, Ult. Wax, etc a couple times a year as needed.
    I did a detail with the polish, Ult Wax, and then HCW for an initial layer a couple weeks ago, and should have a chance to wash again next week and re-apply HCW, so we'll see how it goes.
      You don't have to compound it, why remove even a tiny bit of clear coat if you are satisfied with condition of it. You have products that can do that much easier. Like iron removers (Meg's Iron Decon, CarPro Iron X). Me personally to remove wax and start from clean sheet I user CarPro Eraser, it is something like IPA.
      Although can you top traditional sealant over HCW, don't know. It probably wouldn't bond properly.
        People do stuff like this all the time. No need to over think things. People are constantly applying polymer sealants (designed to bond to paint on a molecular level) over all sorts of waxes found in cleaner waxes (usually a carnauba blend) all the time.
        Go ahead and apply the ULW, and enjoy!
