Ultimate polish
  • Ultimate polish
    Is Ultimate polish a new product? I have been reading though a lot of the writeups on what products to use and its not mentioned on any of the posts. I have a 2012 MINI with what seems to be a decent amount of swirls. The paint is in great condition other than that. Is UP the product I should use with a Yellow pad on a DA polisher? Or do I need to mix in some other steps that are more agressive first?
    The car is a white car and in the sun you can see the swirls. With headlights shining on the rear you can see them as well.
    Re: Ultimate polish
    Must be a year or two old now.
    It has some defect removal ability, so if your paint seems soft, it would be a good option for a test spot first.
      Re: Ultimate polish
      True, but chances are you'll need something stronger, like UC.
        Re: Ultimate polish
        If not that, maybe SwirlX. Slots nicely in between Ultimate Compound and Ultimate Polish.
          Re: Ultimate polish
          Or ScratchX (between SwirlX & UC).
            Re: Ultimate polish
            Lots of options.. So many products in between that can help out..
              Re: Ultimate polish
              I was polishing my black 2012 Acura with UP with polishing pads and noticed some black got on the pad. Not much... just slightly towards the edge of the pad. I have washed the pad since so unfortunately, I cannot provide any pictures.
              Did about 4 passes with moderate pressure at speed 5. The car was clayed and wiped down prior polishing. It is quite possible that I did not do a thorough job of washing the car and it is also possible that the black got on the pad from the plastic and rubber pieces. I am happy with the results I got but somewhat concerned about pad turning black if it is actually some paint.
              Is this a reason to be concerned?
              2012 Acura CBP TL SH-AWD Tech
                Re: Ultimate polish
                If just on the edges, the rubber/plastic trim is most likely.
