Ultimate Polish
  • Ultimate Polish
    Is UP contains any abrasive agents or its just polishing and oil. What is the different between UP and Mirror glaze#7. Thanks
    Re: Ultimate Polish
    UP has some mild abrasives, #7 and Deep Crystal Polish do not.
      Re: Ultimate Polish
      Ok, if I applied UP with Meguiar's black finishing pad is the abrasive will be effective and cut applied to the paint to remove the minor defects or I need to step up to more aggressive pads such as the yellow polishing pad.
        Re: Ultimate Polish
        No way to really predict that without trying some out. I would tend to plan on the polishing pad at least for defects.
        But even if UP and polishing pad would be enough or not.
        You could try a pic of the car, defects, or something like that to maybe give some idea.
          Re: Ultimate Polish
          Is any one and share his experience. BTW I don't have thickness measurement device.
            Re: Ultimate Polish
            Please refer to this post. http://www.meguiarsonline.com/forums...l=1#post440870
            This polish has a very light cut, but with a lot of oil for longer work time. The hardness of your paint will determine how much the black pad can cut. If you want more correction, I would suggest M205 instead.
              Re: Ultimate Polish
              That is a good answer, but if I would like to avoid the cutting ability from the product. Can I achieve that by using the UP with LC crimson pad or CG red or black pad. Whay do you think? Thanks
                Re: Ultimate Polish
                If you want the mildest combination possible, then you would want to use a finishing pad, from whichever company.
