Is it necessary, or beneficial to apply wax after using Color X? Suppose it wouldn't hurt, but would it beneficial? This would be on a daily driver, and on my vette, which isn't a daily driver.
Color X question
Re: Color X question
ColorX is a fantastic product - no doubt about it. I guess the only drawback to ColorX as a wax is that it came about before the addition of Hydrophobic Polymers - like thos found in NXT 2.0 or Ultimate Quik Wax spray wax.
If you want the ultimate protection AND water sheeting properties, throwing a thin coat of NXT 2.0 on there after the ColorX wouldn't be a bad idea.
Either way, you should be fine.
^ +1
Also depends on how often you rewax. If you rewax every 1-2 months, probably no benefit (although it certainly wont hurt). Applying a different carnuba (DC3, #26) probably has zero benefit other than ensuring no missed coverage spots (which is why Meguiars and everyone suggests 2 coats of any wax).
If you go longer, then doing a second coat with a synthetic like NXT2 will give slightly longer protection (probably 2-3 months, but drastically depends on your environment and conditions). In effect you would be using ColorX for its cleaner and its polish/glaze as well as a first coat of carnuba wax, and then NXT for increased durability as the final coat of wax/sealant. NOTE that you dont get double the protection, the NXT probably removes much of the ColorX carnuba, but the end result is a guaranteed full/even coat and mostly NXT2 synthetic (slightly longer protection).
So, add NTX2 if you like, or use ColorX alone (for 1-2 months of "typical" carnuba protection).2010 XRS
Originally posted by vetterman View PostHow about topping it off with GC?
Nothing wrong with GC if you want to do that.2010 XRS
Originally posted by searle View PostI would suggest stick with the ColorX (2 coats)
To the OP - You can always apply Colorx, and then the following week after you've washed and dried the car, apply Nxt2.0 or GC.
Originally posted by imacarnut View PostI would think (could be wrong) that doing another coat of Colorx would strip the previous off since it does have some good cleaning ability...
Doing a Second coat with NXT2 is a little more interesting. Same even coverage logic, but since you cannot layer wax(s), you will end up with some sort of partial-carnuba and partial-synthetic coating. Whatever amount of NXT2 is added (or replaces carnuba) the result will be a little more durable protection.2010 XRS
Originally posted by imacarnut View PostTo the OP - You can always apply Colorx, and then the following week after you've washed and dried the car, apply Nxt2.0 or GC.
I personally usually do an initial detail (wash+clay+cleaner+glaze) and wax with NXT2, wait 4-12 hours and then second coat using #26 carnuba. I then wash weekly, with UQW spray touchup (with its synthetic polymers). Every month or so I re-wax, typically alternating between NXT2 and #26 throughout the summer.
Whatever works for each person, since maximum wax beauty really *IS* largely in the eye of the beholder.2010 XRS
