Reducing Hot Shine Tire Gel
  • Reducing Hot Shine Tire Gel
    I am new to this forum but I have been a Meguiars user for many years and use it in my detailing business. I have always had a question regarding reducing the tire gel. The reason i want to do this is that I have low profile tires on my car and typical low profile performance tires tend to have alot of lettering and some times designs on the tire wall. The problem I have is that the gel is too thick to properly fill the letters and the go around all the edges cleanly. Normaly it builds up on the edges. I understand that reducing the mix makes it less durable, which is fine by me. I have tried sprays and foams and even using them on foam pads its still dosent last as long and flings. basicly I was just wondering if i should reduce it with a water based product or if a high temp paint reducer would be better. Thanks for any help
    Perfected Reflections A.R.P Inc
    2004 Nissan SER SpecV
    2003 BMW 325i
    Re: Reducing Hot Shine Tire Gel
    Why not just use the hot shine spray instead of gel?
    Remove swirls my friends.
      We don't recommend cutting or diluting this, or any, product. What may well resolve the issue for you is to try applying it with a wide paint brush (close to the width of your sidewalls) that has been cut down to bristles maybe just an inch or inch and a half long. That should make it easier to really work the product into and around all that texture.
      If you can locate a Meguiar's Slide Lock Detailing Brush (discontinued item but there are still some out there) it should be perfect for the job.
        I agree. The Hot Shine is probably what would work best here.
          I have the spray and even when it is applied with a foam pad It dosent stick and last as long as the gel. Its too thin. lol. I will try a shorter brush and see what that does. thanx for your help
          2003 BMW 325i
            or you could try using All Season Dressing (ASD) like some MOL members, which you can dilute, and maybe get a better result ? :]
            Ganesa,
            Toyota Vios '05
