Paint Cleaner
  • #31
    Re: Paint Cleaner
    what is the weakest(mildest) paint cleaner megs makes? the scratches i have are so minor u can only see them when the sun hits them and the same goes for the swirls i have(only on the hood of the car)
    • #32
      Re: Paint Cleaner
      Colorx would be weakest cleaner which also has polymers in it as well since in all-in-one type product.
      • #33
        Re: Paint Cleaner
        will dc1 remove the scratches and the swirls
        • #34
          Re: Paint Cleaner
          No, DC1 is too mild.
          Personally, if you actualy want defects removed, I would be starting with SwirlX.
          • #35
            Re: Paint Cleaner
            ok, but i dont want to use something that might do more damage to the paint,and no autozone,strauss or pep boys around me carry swirlx or scratchx, and there are no other car care stores around me, no walmart or advanced auto parts, they only thing they carry is dc1.
            Which is stronger swirlx or scratchx and does swirlx remove scratches to and does scratchx remove swirls??
            • #36
              Re: Paint Cleaner
              Hmm.. I think I got my SwirlX at a Pep Boys.
              Swirls and scratches are all the same thing, that is low points in the paint. Scratches are generally deper/more severe of course, so you would need a stronger product to level the paint more easily.
              Since swirls are milder, SwirlX is the milder product, and then ScratchX 2.0 is the stronger product. But they work the same way, if that makes sense.
              • #37
                Re: Paint Cleaner
                it makes sense and thanks
                • #38
                  Re: Paint Cleaner
                  I would say A-6 Cleaner Wax in the red bottle.
                  r. b.
                  • #39
                    Re: Paint Cleaner
                    i just bought some scratchx2.0 and before i use it i just want to make sure that if i use it for swirls(cause pep boys didnt have swirlx in) i dont want to remove to much clear coat and be screwed, so any tips??
                    • #40
                      Re: Paint Cleaner
                      Start off with a test spot, use a smooth foam pad. Start workingthe product in with a little passion, kind of gently at first, and check your results. Then work up to more passion if needed.
                      • #41
                        Re: Paint Cleaner
                        Pep Boys on 4th Ave does have SwirlX. There was one left on the shelf last time I was there.
                        Calais Auto Detailing
                        CalaisDetails@aim.com
                        • #42
                          Re: Paint Cleaner
                          thats funny cause i went there earlier and i bought the last one on the shelf, everytime i went there before they never had it out,then i went to autozone and all of a sudden they have every megs product on the shelf so i bought some swirlx.how come scratch and swirlx should be applied wit a foam pad and not a microfiber pad? i have some scratches on the plastic that protect the gauges, ive tried mothers plastic polish cause it was the only thing i could find and it didnt work,any suggestions?
                          • #43
                            Re: Paint Cleaner
                            I tend to find smooth foam easier to work with, as opposed to the applicators that are foam, and then covered with something.
                            Like if I need terry cloth for something, I dont like those applicators, I like a piece of terry.
                            But, could just be personal preference.
                            As for your guages, generally PlastX would be the place to start, though I would be curious if SwirlX has ever been tried.
                            • #44
                              Re: Paint Cleaner
                              you know i was thinking of using swirlx, it couldnt hurt right?
                              • #45
                                Re: Paint Cleaner
                                Well... it could...
