View Post
Ultimate compund?
Re: Ultimate compund?
Originally posted by mtldetail View PostI'm working on my 03 SL500.
I can apply ColorX by hand with my megs foam applicator, right?
ColorX is very versatile, it should be in everyone's arsenal.
I can apply colorX by hand with my megs foam applicator, right?
Get some ColorX, wash an if needed clay the paint before applying the wax. When you apply the wax work a small section at a time, about 16" square or so with the idea to really focus on and work the section you're working on so you do a really great job of applying the wax.
After you do one section, leave the wax to dry and move onto a new section and overlap a little into the previous section. Continue this process until you've waxed the entire car or the section you want to tackle for the day.
After the wax has dried wipe it off using a clean microfiber polishing cloth.
You're done and the paint will look great.
Avoid getting this wax on rubber or plastic trim.
By the way...
What are you working on?
You would not have to.
But Meguiars recomends two thin coats of wax for best looks/protection. Also, ColorX does not have the new polymer ingrediants that Nxt 2.0 has, if you wanted to take advantage of that as well.
Cleaner/Wax, which means it contains cleaners, polishes, and wax.
ColorX would be fine.
1. Wash
2. Clay as needed
3. ColorX
4. Wax
is a popular combo for daily drivers.
The DC Cleaner is very mild, which is good for regular general cleaning. And you would not need to use a lot of passion just to work the dirt out. Just work the product in a bit.
Since you are working by hand and since you already have Deep Crystal Polish, all you need to do now is to buy a bottle of Deep Crystal Paint Cleaner. Your method would something like this:
1) Wash car
2) Claybar car, if needed
3) DC1
4) DC2
5) Wax
Have fun!Last edited by akimel; Dec 2, 2008, 07:45 AM.
Originally posted by Murr1525 View PostIs your goal to remove swirls? Or just clean the paint?
I have the Deep crystal polish which I was planning on using after I clean the paint. When applying that by hand should I be using passion?
Also, I don't have DA, but I do have an orbital buffer (3200orbits/min) however I purchased that before I started reading on this forum and after all the reading I've done I've come to the conclusion that the orbital is virtually useless so I do all my work by hand now.
Thanks!
Originally posted by mtldetail View PostOk great! Thx for the info guys!
So what would u guys suggest as a good cleaner? I already have scratchX but I'm not about to scratchX the whole car, my arm will fall off :-)
M09, M80, and M83 are all very good options.
