NXT Wash vs. Deep Crystal Wash?
  • NXT Wash vs. Deep Crystal Wash?
    My car has NXT on it and I've been washing it with Deep Crystal wash because that's what I had before I bought the bottle of NXT. I suspect that's not an issue.
    My question is, does NXT wash work better with the NXT polymers than Deep Crystal to make the wax last longer?
    I could donate the Deep Crystal to one of several teen fund-raising car washes and replace it with NXT wash (provided I can find some).
    - Tom
    I have not tried the Deep Crystal Car Wash. The NXT Car Wash is all that I use. It is hard for me to find locally so I have to order direct. The NXT is highly reommended if you have hard water. It really does cut down on water spotting. It does show some anti-static proerties too. The water sheets off very well when used on an NXT or MPPP treated surface. I suppose it would work well with other waxes too.
    RamAirV1
    2006 GTO Impulse Blue
      The Deep Crystal Wash is an excellent product. Use it up with confidence before you switch products. Are there differences? Of course. Will you see them? Absolutely not. The differences are more use-related than appearance-related. NXT sheets better and rinses more quickly, and smells better. DC will need a more thorough rinse, and since it doesn't sheet as well, will require a bit more drying.
      BOTH do an excellent job of removing dirt safely.
      Tom
        I can't find NXT wash in my area so i use Deep crystal and it does a very good job. After the wash i wipe it down and it looks fine.
        I would like to try the NXT wash though.
          Same here, 4.6.
          Walmart has the NXT tech wax, protectant and spray wax -- but not the car wash. Meijer has plenty of Meguiar's products but not NXT.
