Super Degreaser vs All Wheel Cleaner
  • Super Degreaser vs All Wheel Cleaner
    just wondering what you guys prefer to use to clean tires and rims with, i used one on each tire and the all wheel cleaner imo cleaned it better, before i agitated more with a brush and pressure washer.
    btw i used the super degreaser at a 4:1 ratio to make it a lil stronger
    If you like my work please like my FB page
    https://www.facebook.com/Ultimatecardetailingoc
    Re: Super Degreaser vs All Wheel Cleaner
    Either one will work just fine, as you've discovered, but both will carry the same precautions of cleaning one wheel at a time from start to finish (ie, don't spray onto all four wheels and then start agitating the first wheel), rinsing thoroughly with water, and keeping them off delicate bare aluminum or other easily damaged surfaces. 4:1 should be as strong as you'll need Super Degreaser, and in many cases 10:1 will be more than enough.
      SD @ 10:1 is good enough.
      Agitate with a Daytona wheel brush (or similar)and wheels are clean
      "STRIFE" aka Phil
        thanx guys for your responses
