Using Meguiar's D/A Microfiber Correction System
This is a sticky topic.
  • #31
    Re: Using Meguiar's D/A Microfiber Correction System
    Originally posted by Woodie6250 View Post
    One question I do have - the G220V2 comes with the W68DA backing plate. I used this together with the DMC6 pad. Do you foresee any problems with this combo?
    Really, our S6BP is a better choice due to it having the hook & loop all the way to the edge, which gives better support overall and prevents getting any bit of trim, etc caught between that open edge of pad and backing plate. One of the great things about this system is how close these pads can come to an edge and still provide cut.
    • #32
      Originally posted by wifpd4 View Post
      Has anyone tried the D/A MFCS on a clear bra? Or like decals or stripes, don't do it.
      You said it....... probably not a good idea. Not a good idea at all.
      • #33
        Originally posted by Alfisti View Post
        Michael, invariably people will try these new pads with different compounds/finishing polishes, be they Megs other polishes or other brands.
        Any comments on what they should expect if they try this?
        Originally posted by David Fermani View Post
        I find them to work great with other products.
        As David says, you can expect excellent results with other liquids as well. What you may find, however, is that other liquids will create more dust, may not be anywhere near as easy to wipe off, and may not give a huge amount more cut than this system. Of course, how much cut you need is going to be dependent on how hard the paint is, how bad the defects are, etc. But if you've read through the reviews that have been posted in the past 18 hours or so, you'll see several cases of people removing sanding marks with the cutting disc and DA Compound. Do you often need much more cut than that?
        • #34
          Mike,
          Does the finishing wax(D301) contain *any* SMAT or DAT abrasives, or is it a chemical cleaner/wax/sealant product? Also, do the MF finishing discs have any cut?
          • #35
            The D301 does contain some very fine SMAT abrasives, and it is these coupled with the light cutting action of the microfiber finishing disc that refines the paint following the compounding step, actually removing any haze created by that first step.
            So, yes, there is mechanical cutting going on with both the liquid and the disc.
            • #36
              Thanks. Does D300 finish as good as Ultimate Compound? Generally speaking..
              • #37
                Thanks Mike, that's good to know.
                On the flip side, can both polishes be used with foam pads, or will one run into problems?
                I know they're designed to work within a system but people will try things.
                Paul Marmarinos
                • #38
                  Mike,
                  How about using this System on factory single stage paints? Is there gonna be any problem with that?
                  The pad conditioning brush was designed specifically for the System or any brush will do the trick?
                  • #39
                    That totally depends on the paint - we've seen cases of it finishing beautifully and cases where there was noticeable haze. But the Finishing Wax/Finishing Disc cleaned up that haze with just a quick application.
                    In fact, the SL55 AMG shown earlier in this thread displayed very noticeable hazing following the compounding stage, but just a quick application of Finishing Wax brought out the final finish you see in those pictures. Oddly enough, the Corolla didn't show nearly as much haze.
                    Sure, you can use the liquids with other pads. In fact, on extremely delicate paint you may find a foam finishing pad yields a clearer finish than the microfiber disc does. Those will be rare cases, and only with extremely delicate paint.
                    Mike,
                    Factory SS should pose no problems. Our new pad conditioning brush may look like it's just a black version of another popular brush, but we had the bristles altered to be a bit softer and therefore less aggressive on the pads. But overall, any decent pad brush should get the job done for you - just use it frequently!
                    • #40
                      Awesome write up!
                      Thank you for the detailed breakdown of the new system
                      • #41
                        That's surprisingly good news! This 'system' seems to be a winner on all levels.
                        Paul Marmarinos
                        • #42
                          I'm waiting for the reviews about the new MF pads used with more traditional Megs compounds and waxes such as M105, M205, M21 etc.
                          I'm keen to buy the pads and use them with the compounds / polishes / waxes I already have...
                          • #43
                            Now I need a kit to try it out. This one is going to open the world of polishing to alot of folks.
                            • #44
                              Not sure quite exactly what we're allowed and not allowed to post. But you won't be disappointed
                              2008 Meguiar's Batmobile Team
                              2008 Meguiar's/Ford SEMA Team
                              2009 Meguiar's/Ford SEMA Team
                              2010 Meguiar's/Ford SEMA Team
                              • #45
                                Please Nick, do tell us more!
