If I just used #83 with the PC, would it make a difference to follow that up with #7 using the PC and a yellow pad? Is #7 OK to use with the PC? Is it milder than #83? #80?
Question about #7 ?
Hey,
Meguiar's #7 rich polishing oils will help further beautify the surface. So while you may not see a big difference from the #7 after the #80 or #83, if you follow with a coat (I like to use 2 coats to provide uniform coverage) of #7, you will see some improvement. If your paint is at 90%, bringing it to 95% may not be noticeable to some, but it will be to others. If the original level of the paint was lower, the change would be more dramatic! Moreover, some colors are affected by it more than others. For example, dark colors will show more than light colors. However, on light colors, I have found that it will give the paint a deep, highly reflective look!
I have used #7 Show Car Glaze for many, many years and will continue to use it!
I just stopped at Pep Boys and noticed that they had some 6,7,9 and 26 on the shelf. I wasn't sure whether to get the 7,9 or 26. I ordered a 32 oz. bottle of #80 with my PC but that hasn't come yet. So I figured I would pick up a bottle of 7 and try it out. It's gonna be a rainy week here but I'm anxious to try everything out and see how it looks. I've never used it before so we'll see how the finish looks afterwards. Any tips for applying or removing it???Jason
2004 Jetta GLS 1.8T
Hey,
Hope this helps! It is a write-up made by Mike Phillips regarding the application/removal of #7 Show Car Glaze
Hopefully Mike's write-up covers it!!As someone else pointed out, #7 is a high oil content product. In fact, it's mostly oil. I could tell you more about it, I have over 7 pages on just this product alone in my forthcoming book, How to Polish Paint. it's really quite a unique product.
For the last 15 years I have seen a lot people comment as to how hard the product is to get off.
Usually, (and I'm not saying this is what your did), the person makes a couple of mistakes.
#7 is a non-drying oil.
One of the many things it can be used for is to make paint look wet, thus the name? Show Car Glaze.
The reason it can do this is because it is a non-drying oil. Think about it, when you get a brand new paint job, or if you spray some rattle can paint? before it dries? it looks wet, because it is. It hasn't dried.
It's hard to get the "Wet Look" with something they dries, especially if it turns white/opaque.
You cannot make something "more clear" with something that is "opaque".
#26 Yellow Wax, (which is a polymer/synthetic for the most part), dries clear, it does not turn white. It turns the surface very dark and deep however.
So the mistake most people make when using the #7 is this.
1. They apply it to thick - this makes it extremely hard to remove
2. They try to remove it like a wax.
Two tips.
First Tip - Apply #7 with a thin coat
Anybody's product when applied thick is hard to remove, just read the Zaino threads. Same thing applies to most of the Meguiar's waxes. A thick coat does nothing but waste product anyway, think about it. you wipe the excess off, i.e. the stuff sitting on top.
The idea is to "Push" the product into the pores of the paint, allow it to cure or dry, (if it's a drying product) then wipe off the material remaining on the surface. Sure some product remains on the surface, and there are a lot of opinions concerning "Layering", but suffice to say, there is a point of "Diminishing Returns".
If it were true you could create a "film-build" of product, that would mean that after enough coats, you would no longer be applying a coat of product onto paint, but in fact would be applying a coat of product onto a "film-build of product", (In other words, your layers of wax/polish/protectant/polymer/sealant/synthetic, or whatever word/term you want to use to describe your protective coating.
Kind of like trying to re-create a "Clear Coat". Last time I checked, nobody's product is clear, at least not like the clear resin a clear coat of paint is made from, (clear resin is often slightly amber in color)
So I don't know if I subscribe to the "Layering" theory. I am experimenting however, with multiple coats after coat of product on my black demo panel here in my office, so far, no "visible film-build". I do believe that two thin coats are better than one, and three coats wont' hurt. After that, I don't know. I would at least let some time go by.
So apply #7 thin. Use a soft foam applicator pad.
Second Tip - Removing #7 requires a special technique, not the same kind of technique you remove a wax with.
Most people remove their wax like this. Start in one area, begin wiping until all of the wax is removed in that area and then move on to virgin territory.
This will not work for #7. The "Act" of removing #7, tends to "Re-liquefy" the product, basically creating the smearing around effect that you experience when you apply it.
Instead, "Break" or "Disrupt" the "Continuous" layer of film-build and then move on to a virgin area and "Break this film-build up.
You see, #7 doesn't actually dry, but? it will "Skin", somewhat like homemade pudding.
This "Skin" is easier to break up and remove then the more liquid film is.
By breaking up the continuos film-build and then moving on, you are exposing a fresh layer of the film to the air where it will skin. The next time you come around, it will be easier to break up and remove.
So the idea is to apply a thin coat to the entire car.
Then, Go around the car two to three times, removing a little bit at a time.
A big soft, high quality, 100% cotton, terry cloth towel works best for the first two passes, and then switch over to a Microfiber polishing cloth for the last pass. Microfiber polishing cloths have an affinity for both water and oil based liquids and will remove oily residues much better with less fiber inflicted scratches.
Anyway, that?s what my experience has taught me after applying and removing gallons of #7 over the years, to every kind of car with every known type of paint.
Another person mentioned it will wash off. This is true. #7 is a "Body Shop" safe polish. It has no "Lasting Characteristics", i.e. it contains no ingredients that will affect "Paint Adhesion", typically waxes or silicones. (There are what are called, "Paintable Polymers", Meguiar's uses these in the "Speed Glaze", a body shop safe, cleaner/polish).
#7 is not meant to last. The idea is it will not semi-permanently "seal" or "Cap" the pores of the paint. (waxes, sealants, synthetics, polymers, whatever you prefer to call them act to semi-permanently seal or cap the pores of the paint. Nothing is permanent, at least not according to the theory of Entropy. This can lead into an entire discussion of "Permeable and Impermeable, but I digress).
This is important when used on solvent-borne paints because it allows the solvents to continue to work their way out of the paint resin through "capillary-action", (I think). The idea being that paint that is fully cured will be harder and last longer than paint that is not fully cured, i.e. softer and will not last as long.
How important this is to Catalyzed paints I do not know. The Synthetic wax crowd usually tells everyone it is safe to wax catalyzed paint shortly after they are sprayed. While this may be safe, I know that paint manufactures "Still" recommend waiting 30/60/90 days before you apply any type of "Sealant", i.e. wax to the surface. Best to follow manufactures recommendations when dealing with something as expensive a s new paint job, not to mention all of the work and inconvenience getting a car painted causes.
#7, in my opinion works better on single-stage finishes, either modern or traditional. For the wet-look, either Deep Crystal Polish, (very much like #7 but in Meguiar's Consumer line), is easier to apply and remove or #80 Hand Polish in the Meguiar's 80's series, (Body shop products, only comes in a quart).
I'm sorry you had a hard time applying and removing the product, perhaps if you try again, following my tips you will have better results.
By the way, as someone else commented, usually, #7 is applied first, then wax is applied over it. This is because the #7 is water soluble and the wax isn't', thus the wax will act to "Lock" or "Seal" in the #7.
However? right before a show? to make the paint look wet and to fill in hairline scratches, it is perfectly aright to apply the #7 on top of the wax, thus the name? Show Car Glaze.
It was never formulated to be a lasting product, but instead a Beauty product.
Now I know the Zaino crowd, including Sal, don't like using "oily" product on their paint for a host of reasons, I understand this fully and also agree they have a point.
With that said? if your goal is to make the paint it's darkest, deepest and wettest looking, then I submit your best bet is a product that is oily and doesn't dry. Yes, it might be temporary, but the show only last one to two days sometimes three.
The name is Show Car Glaze, not water beading, long lasting durable Miracle Wax.
You also might give the #26 a try for a dark, deep finish like you black corvette.
No it doesn't bead water as long as Zaino and many other waxes, the #26, Gold Class and even the Medallion were never formulated to "Bead Water".
If you want to see a wax that will bead water? try the Meguiar's Cleaner/Wax in the Maroon bottle, make sure it says "New and Improved on the label.
Our chemist reformulated it to "Bead Water Like Crazy" because of consumer demand. Only costs $5.00 a bottle and works great for most people.
I'm sure they could do this for are other products but the idea, I think, was to make a wax that didn't bead water to avoid deep chemical etching that is caused when these tall beads dry on the finish.
Of course this doesn't matter to hard-core enthusiasts that dry their cars after washing.
That's all ? hope this helps,
Thanks a lot Tim, very informative and helpful. After reading it, I think I'm going to exchange the #7 for some #26. I've got a clear coat paint and after the write up it sounds like some DC#2 might work better if I still want to use a polish. Thanks for your help.Jason
2004 Jetta GLS 1.8T
