Wats the best way to remove old wax?
  • Bert31
    replied
    Re: Wats the best way to remove old wax?
    Just go from one process to the next, you don'th ave to wash the car in-between processes.
    Wash --> Clay --> Clean --> Polish --> Wax
    Thanks Mike, I will keep that in mind in future details. My next detail will be an exception though, after washing, claying and paint cleaning I have a few paint chips that will need some touch up paint. After a day or two of drying for the touch up paint, I will obviously wash off all the dust accumulated during those two days before going on to wet sanding the touch up blobs and then compounding and polishing and so forth.
    At least when using the Meguiar's product line as our chemist made all the products they know how to make each product build off the results of the previously applied product.
    By staying inside a single product line there is Synergistic Chemical Compatibility. (SCC)
    Wow, try saying that 10 times fast w/o goofing it up.
  • Mike Phillips
    replied
    Originally posted by HemiMopar View Post
    I have used Meg's but the towel gets saturated before I make it all around the car and by the end it is absorbing some but still tends to just push it around and it dries before it is removed completely.
    Have a few more microfiber polishing cloths on hand for the claying step.
  • HemiMopar
    replied
    If you're using a quality mist & wipe detailer and a quality clay bar then you should be able to wipe the residue off using a quality microfiber.
    Be sure to work a section and then wipe it clean, don't go around the entire car and then try to wipe the car clean. Work a section at at a time.
    We demonstrate this at all of our Saturday classes on all kinds of paint systems without problems and then turn people that have never clayed before in their lives loose to try their hand at it.
    If there is any residue left behind then "Yes" the next step will remove this whatever the next step is, paint cleaner, compound, cleaner/polish, pure polish, wax etc.
  • Mike Phillips
    replied
    To add to his question I notice after I clay there is a lot of lubricant that doesn't completely get removed and leaves it streaky and hazy (not damaged paint but just a residue). Would it be okay to wash that off or can we still continue with the next step?
  • gsxr310
    replied
    you would want to remove the lubricant w/ a mf towel if you're done claying the vehicle.
  • HemiMopar
    replied
    Originally posted by Bert31 View Post
    Would you wash the car between paint cleaning and polishing or just go straight from paint cleaning to polishing? I didn't know if paint cleaners leave behind any residue that should be washed off before polishing.
  • Mike Phillips
    replied
  • Bert31
    replied
    Degreasers when used as wax removers are not intended to make paint look good, (as in part of a system of making paint look good), but chemically strip the paint.
    A well designed/formulated paint cleaner will remove anything off the surface and leave the paint looking good, (as in part of a system of making paint look good), and also leave it perfectly prepared to either wax or polish and then wax.
  • Mike Phillips
    replied
  • J. A. Michaels
    replied
    But I would probably be thinking it is time to do the complete cycle. For this I would go ahead and clay your vehicle. Then give it a fresh lsp.
  • yalerd
    replied
    A mild paint cleaner will remove any coat of wax present in the surface.
  • akimel
    replied
    If the wax has been on the car for many months and the car has been exposed to the elements, then most likely it has worn off. But regardless, there is no need to resort to a degreasing agent. Simply clay the car and apply a paint cleaner (e.g., Deep Crystal 1). That will take you back to the base level. Here are some threads where the question has been discussed:
    Hi, I recently bought a new 2008 TL and recently waxed it using the nxt liquid wax. It is a black car and Im wondering how many times do i wax a car before i should strip off the wax? I heard that dawn dish detergent strips off wax fine but is that really safe for car paint? does meguiar have a product for this and what would
    Hi, Just wanted to say I should have found this forum earlier! I love detailing ;) now - on the the question: i've only waxed my beetle with GC and NXT, but I think it's time to go deeper and start over. Do you suggest using Dawn to wash, or using the paint cleaner to remove the old wax? - the paint cleaner is from
    I was thinking about starting from scratch and am looking for a way to remove all previous layers of wax off my car and start fresh. From what I understand Clay barring a car will remove some wax. Is there any kind of car wash solution you can use that is highly effective in removing wax? What is the best way to remove
    Hope this helps.
    Al
  • angchor
    started a topic Wats the best way to remove old wax?
    As above. Should i use a Meg degreaser since it can dewax?
