Streaks with glass cleaner concentrate...
  • Nick Chapman
    replied
    Re: Streaks with glass cleaner concentrate...
    Yes. Dedicated microfiber towel for all glass cleaning.
  • BlueZero
    replied
    Are you using a dedicated microfiber? Reason I ask is if your using one that was used for removing wax it could be causing the problem.
    I spray the cleaner on wipe it with a microfiber then after it's dry I flip the towel over and go over it once again with the dry side of the towel. Seems to work good for me.
  • Nick Chapman
    started a topic Streaks with glass cleaner concentrate...
    I've followed the directions with the glass cleaner concentrate in the Detailer line(10-1 dilution ratio), but I continue to get streaks Should I mix more water with it to help out a bit?
    Thanks,
