I just spent close to 10 hours methodically polishing my black G35. The paint wasn't too bad, but being as OCD as I am, I wanted to get the paint better than new.
I have been using Griot's polishes with good results for several years now. I used their #'s 1, 2, 3, and 4, with 4 being the finest in abrasives and with micropolishing properties.
What I like about the Griot's is the transformation/changeover as the abrasives begin to break down. As you work th polish, it gradually breaks down until it becomes clear-like. So, I can easily tell when the polish has done its job.
I decided to try the #80 and #82 as well. The first thing I noticed was how easy the compound squirts on the buffing pad and how smoothly the buffer runs over the surface. I was doing speed #4 with a W8006 pad.
One of other things that I noticed however was how oily/lubricated the 80 and 82 were. I worked the surface well, but didn't see the changeover like I did with the Griot's. When I felt I had done a section sufficiently, I wiped the area off with a mf towel. The paint looked incredible and had a deep gloss to it compared to the Griot's.
What I am looking for is for a recommendation about how long to work both polishes. Should I use a different buffer speed or is there something else I should be doing? Should I go with a higher speed as well, something like speed #5? BTW, I am using a Griot's random orbital buffer that is quite similar to a PC.
I'd appreciate more insight into these two products. I like how they did the surface, but I just want to make sure I am correctly using them. Thanks for your help.
