Could anyone post bottle label information and instructions of Meguiars All Purpose Cleaner D10101?
All Purpose Cleaner label instruction?
Re: All Purpose Cleaner label instruction?
Originally posted by ktlimq View PostCould anyone post bottle label information and instructions of Meguiars All Purpose Cleaner D10101?
Dilution:Heavy Strength 4:1
Medium Strength 10:1
Application: Test small, inconspicuous area for colorfastness prior to use. Apply properly diluted product to surface. If necessary, agitate with a soft brush or clean terry cloth towel. Using a fresh towel, absorb the excess product until surface is dry to the touch. For continuous use, mix concentrate and water in a bucket. Using a brush or towel, scoop out foam and clean desired area.
Professional Tips: To quickly clean floor mats, spray properly diluted product over entire mat, agitate heavily soiled areas with a brush, rinse with high pressure stream of water, vacuum excess with a wet/dry vacuum and hang dry. Use a foam sprayer tip and Meguiars All Purpose Cleaner to clean hard to reach areas such as doorjambs. Rinse thoroughly with water.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Originally posted by BlueZero View PostJust a thought on this subject. Would it be possible to get scans of the labels of all the bottles posted somewhere. Kind of a handy reference. Just a thought.That would make alot of sense. Aneat quik reference guide.
Originally posted by Top Down View Post
Where the light hits, it says "is ideal for."
If you need the Hazard rating, it's a 2 for Health, and a 0 for the other three categories."Meguiar's, Im back home Again, and plan to Stay!".
They call me "Blue"
Originally posted by Top Down View PostWhere the light hits, it says "is ideal for."
If you need the Hazard rating, it's a 2 for Health, and a 0 for the other three categories.Brandon
Thank you very much.
"Using a fresh towel, absorb the excess product until surface is dry to the touch."
This does not sound realistic to me (I am not a professional detailer).
When I used the consumer line Heavy Duty Carpet & Interior Cleaner, I wiped with clean terry towel to transfer the dirt to towel and make the surface less wet, and then let the cleaned surface air dry.
This is what (now unavailable) Barry Meguiar's video (a good introduction to interior, exterior, and engine cleaning) instructed, too.
Some competitors upholstery cleaners (Mothers, Prestone) are designed to be used in this way: removed excess with terry towel, then let dry.
Because the professional line all purpose cleaner contain harsher chemical, we should dry it with towel until the surface is dry to the touch, while we can let the consumer line Heavy Duty Carpet & Interior Cleaner dry by itself in the air without worrying about damage to the treated surface?
