One Step Compound VS. Heavy Duty Oxidation Remover
  • One Step Compound VS. Heavy Duty Oxidation Remover
    Having only really used Heavy Duty Oxidation Remover in the marine line.... can someone compare One-Step Compound to Heavy Duty Oxidation Remover? Is one more aggressive than the other, is the 'one-step' title mean there is wax in the product? Any help would be great!
    Brandon
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    Yes, it is supose to be more aggressive then Heavy Duty Oxidation Remover. I used it on the top of open bow on my boat where the sun really beats on it in the summer and it pulled the oxidation right off. I used #49 on that area 3 times, then stepped it up to #67 and did a excellent job after 2 passes.
    Funny thing is with the product (just tried this, because I meant to do it when I was using it and forgot) but I put some #49 and #67 on a finger in each hand and rubbed them together. #49 seemed more abrasive then #67, but #67 was a thicker product. I followed with the Flagship premium wax and I prefer the over the #56.
    Front of the #67 bottle...
    -Aggressive Compound Cleaner Plus Polish
    -Effectively removes severe surface degradation and restores shine and luster to all gel coat and fiberglass surfaces
    - Excellent results by hand of machine... That is no lie!!!
    Back of the #67 bottle.....
    "Meguiars now introduces a more aggressive, cutting compound to remove heavy oxidation from high solid gel coats!! This one-step compound is specially designed to both clean the gel coat surface and leave behind a high gloss finish. It will remove moderate to heavy oxidation, tough hard water spots, stains, and light to medium scratches. Thus restoring the color and leaving a rich gloss on the treated surface. Excellent results by hand or machine. Aggressive, yet safe, Meguiars new compound reduces the steps to treating neglected surfaces, by creating a compound and polish in one."
    At the bottom of the lable..
    Tips: Meguiars No. 67 One-Step Compound will feed the gel coat with valuable oils and will generate a rich gloss. For Long lasting protection, follow with Meguiars No. 56 Boat/RV Pure Wax.
      Has anyone used 44? What is it like? I'M fixing to do a buddy's boat thats in good cond. Was thinking of 44 and then 63. I want
      to sell him on MEGUIAR'S, HE has been a brand X guy. I think there prod. are hard to use and with poor results.
      THANKS
        See this thread... Oxidation Removal I have never used it, but if the boat is in good condition give it a try.. If you need a little more bite jump up to #49. I like to apply a pure polish before my LSP and my choice on that is M03 then I will use #63 which is the way to go!! I have NEVER seen a wax come off so easy. Great protection aswell.
        THANKS
