How to remove Stained aka water mark from glass by KC
  • How to remove Stained aka water mark from glass by KC
    Waterspot or watermark is a very common problem. Most cars are constantly being subjected to the Daily harshness of acid rain, Contaminants in the air, Hard water, etc and Left off drying in the blazing sun. moreover it is so irritating to see the watermarks on the glass and it is dangerous to drive especially in rain
    Hard water stains, or acid rains and other minerals in your water.
    While these stains are hard and tough to be removed, there are several cleaning and prevention methods that can help get your glass back into sparkling condition.
    how to check for water spots
    use a damp cloth to do aquick wipe - spot will appears and use this to check for uncorrected stains
    take note
    some commercial car wash uses
    1. ACIDS - they are quick and most effective - Muriatic acid or hydrochloric acid is very dangerous......To remove hard water spots from your glass might be a nightmare.You had to buff with hard ... Hydrofluoric acid is a dangerous chemical and if you have asthma or any breathing disorder....which some "so call reputable" detailing centre uses
    q
    warn against using hydrofluoric or hydrochloric acids to remove water spots on glass. Not only are they dangerous to glass, but they are dangerous to the employees
    2. Osren Glass polish - with 3M sanding foam- effective but requires lots of elbow grease
    3. Machine polish - Cutting with Meguairs Compound M105 with Meguairs Cutting Foam pad Speed - 3with Makita between 1200-1500, gently with generous misting with water....never use force or let the product dry
    Then Finishing with Meguairs Polishing M205 with Meguairs Cutting Foam pad - Speed - 3with Makita between 1200-1500....repeat if necessarily
    tools requires
    1. polisher
    2. Compound/polish
    3. flood light
    4. misty spray bottle
    5.Tape - you do need to tape the rubber parts ...least it get whacked during your correction
    6. I uses Meguiar's D12001 Glass Cleaner Concentrate for final inspection and removing all polishing residues and oil Glass coating - for protection
    opsssss....window stains
    ehhhh
    use a damp cloth to do a spot check for stains
    i wouldnt sure if I would do the glass coating on these stains
    before
    after correction M105 and polishing with M205
    always
    remember tools # 5.Tape - you do need to tape the rubber parts ...least it get whacked during your correction
    final inspection
    polish residues is hard to remove - at times.......use damp cloths ...effective and safe your time to check for uncorrected area
    i use damp cloth to wipe
    let it dry prior uses Meguiar's D12001 Glass Cleaner Concentrate for final inspection and removing all polishing residues and oil Glass coating - for protection
    conclusion
    I would strongly urge you to avoid this
    Also encourage you to choose where you park? SHADE under tree.....mango tree saps! dripping down water from yourroof? leaking pipes or ceiling at apartments??
    taking up your ownership !!! and be proud of your ride!
    have fun and wish you all the ......to your attempt
