Headlight Lens Restoral on this older cat by Innovative Detailing
  • Headlight Lens Restoral on this older cat by Innovative Detailing
    Headlight Lens Restoral performed correctly by Innovative Detailing on a 2000 Jaguar S Type. This cat was going blind from yellowed, hazed and dull lights resulting in poor night visibility, safety issue and ugly asthetic appearance. Options are replaceing which can cost lots of money when restoral is a fraction of the cost.
    Before Headlight lens restoral
    After Headlight lens restoral
    Headlight lens restoral prep and tape
    Headlight lens restoral Step 1
    Headlight lens restoral Step 2
    Headlight lens restoral Step 3
    Headlight lens restoral Step 4
    Headlight lens restoral Step 5
    Headlight lens restoral Step 6
    Headlight lens restoral Step 7 LSP and completed
    This cats eyes are clear again
    Thank you for viewing.......
    For a complete video of this process you can go to my Youtube page at InnovativeDetailing1
    David M. Sylican
    Detailing Caddy
    Join us on Facebook
    Re: Headlight Lens Restoral on this older cat by Innovative Detailing
    Thanks David
    I learn something new
    thanks for taking time to write out & explain step by step...very informative
    the last time i tried on a caldina, took me almost 2 hours & cant achieve half of yours
    as i did not sand off the cataract layer & nearly finish off 1/4 Plastic X
    BTW what product u used & pad combinations
      Thanks David
      You are very welcome KC, here are a couple of videos showing the complete technique and one has annotations of the process
      http://www.youtube.com/watch?v=Uxyo5O-xw2Q - Slide show of Jaguar
      http://www.youtube.com/watch?v=260TxpkxgOk - Slide show of Jetta
      Please feel free to rate or add comments to my Youtube page.....
      David M. Sylican
      Detailing Caddy
      Join us on Facebook
        thanks David
        just curious what sand paper use? product & pads? tqs
          Great work on the headlights. They look fantastic.
            Indeed they look absolutely fantastic. Thanks for the share.
              thanks David
              Good luck. I don't think he is going to tell you anything regarding the sandpaper or product used. As shown in his video, it is "secret sauce".
              Colin
                thanks David
                just curious what sandpaper use? product & pads? tqs
                Sure.......
                I use 3M paper, Imperial and Trizact and the pads are also 3M, cutting, polishing and finishing. Tools I use Blue Point (Snap On), as for product there are so many to choose from, I like what I use the best......But experiment for yourself and try different manufacturers products to see what gives you the best results. I think the M105 - M205 combo should work just fine!
                David M. Sylican
                Detailing Caddy
                Join us on Facebook
                  Great work on the headlights!
                  This process is exactly what we recommend with our new Professional Highlight and Spot Repair Kit. While you need an air compressor to run the mini tools (D/A and rotary) as shown here by David or the tools in our kit, you can use the hand pad that comes in our kit for the sanding and then use a rotary with 4" pads for the final buffing. All of the pads, sanding discs and finishing discs in our kit will be available separately if you don't need/want the mini air tools.
                    Originally posted by Innovative Detailing View Post
                    Sure.......
                    Thanks David again
                    wow...it takes a cobbler to know his tool, certainly u does
                    thanks again
