My "rustoleum $50 roll-on paint job"
  • My "rustoleum $50 roll-on paint job"
    Well it finally happened - the hood of my mustang which I used to learn the rotary on finally oxidized so badly I had to do something.
    Hot Rod magazine did an article on how to paint your car with Rustoleum and a foam roller...so I thought I'd give it a try! With Gloss Black (what did I get myself into???)
    Here's what I started with:
    Here was my process:
    • Wash hood with hot water, powdered Tide, and a red scotch brite pad
    • Sand with 80 grit disc on PC to remove most of the layers of old paint
    • Sand with 220 grit disc on PC
    • Sand with 320 grit disc on PC
    • Prime with Rustoleum automotive spray primer
    • Sand with 320 grit using palm sander
    • Prime again
    • Sand again with 320 grit
    • Applied rustoleum mixed 50/50 with mineral spirits using a high density foam roller (2 coats, 12 hours apart)
    • Sanded with 600 grid and Meg's foam block
    • 2 more coats, sanded again
    • 2 more coats
    • wetsanded with Meg's foam block and 1500 unigrit
    • wetsanded with Megs foam block and 2500 unigrit
    • Compounded with PC, 5.5" LC yellow foam pad and M105 (2 passes)
    • Final polished with PC, 5.5" LC green pad and M205
    Whew! Sounds like a lot but doesn't really seem like that much work.
    here's the final result:
    Not too shabby for an amateur painter, a foam roller, and $75 worth supplies (still enough left over for the rest of the car!)
    Thanks for looking
    Re: My "rustoleum $50 roll-on paint job"
    Sitting with mouth open. WOW Grrrrrrreat job.
      You have GOT to be KIDDING!!! Amazing.... must give this a try someday.
        kidding me. .....i want to learn how u did it.....thanks for posting
        amazingly finished
          Wow! Wow! Wow!
          That "thing" in my avatar is painted with rustolem but does not look anywhere near as good as that. Awsome job man.
          Professional Automotive Reconditioning Services
          "You scuff it-I buff it!"
              I would recommend it for daily drivers or cars with dead paint. Can't beat the price! It's pretty easy to do as well. I wish I had an air DA sander for the wet sanding, but that wasn't too bad either. Give it a try, you've got nothing to lose
                amazingly finished
                I used these 2 websites as a guide:
                HOT ROD is “where it all began,” as the first magazine to cover the hot rod culture. Since that time, HOT ROD has evolved into a brand devoted to everything from hot rods to restomods, barn finds to project cars and everything in between.
                I say go for it!
                  Originally posted by THE BIG BUFFER View Post
                  Wow! Wow! Wow!
                  Thanks Wetsanding with Meg's Unigrit and then compounding with M105 followed by polishing with M205 makes all the difference.
                  I realized in my paint correction work that I could make any paint look good as long as there's enough paint to work with.
                    Great job
                      Wow. I am totally shocked. What great results.
                      I commend you for taking this precarious and arduous endevour.
                      No clear coat correct?
                        Thanks No clear coat, this is a single stage enamel. And really not all that arduous LOL
                          Originally posted by FIREBOY View Post
                          Great job
                            That's pretty cool. I had no idea people were doing this.
                              Wow I'm suprised rustoleum can look that shiny! I'm curious though, why not use one of the spray enamel automotive paints that come in an aerosol can at places like autozone? I mean those paints are actually made for cars and still relatively cheap
