Headlight Restorations
  • Headlight Restorations
    after
    before
    after
    before
    after
    before
    after
    www.ozcarwash.ro
    Atelierul de cosmetica auto din Craiova
    Re: Headlight Restorations
    Very nice results!
    David M. Sylican
    Innovative Detailing
    Headlight Lens Restoral
    Detailing Caddy
    Join us on Facebook
      Thank you.
      before
      after.
      www.ozcarwash.ro
        before
        after
        before
        after
        after
        before
        www.ozcarwash.ro
          Very good results. They all look great.
            Thank you.
            www.ozcarwash.ro
              what you do to them? looks fantastic!!
              oh the last pic you have "before" and "after" mixed up
                Great question. I know several MOL members would be very interested to learn what steps you use to achieve these fantastic results.
                  Is an honor for me to share with you my method of working:
                  For begining you need: 1) sandpaper 1000-1500-2000-2500-3000 grit (i used mirka sandpapers)
                  2) Sanding Backing Pad like this
                  3) Rotary polisher(go and manually but you need muscle ), foam pads and polish paste.[ i used makita 9227 cb, 3 foam pads from 3m (green,yellow,blue) and 3m Fast Cut Plus(green plug), Extrafina(yellow plug) Ultrafina(blue plug) ]
                  If headlights are affected as in the pictures above you start with:
                  1000 wet sandpaper (very important, use wet sandpaper ) then after covering the surface evenly go to 1500-2000-2500-3000 grit.After sanding follows polishing.
                  www.ozcarwash.ro
                    Fantastic results, looks better then new
                      Thank you.
                      www.ozcarwash.ro
                        Headlight Restorations Renault Laguna
                        I used wetsanding 600-800-1200-1500-2000 grit, and then polish with 3M fast cut plus and Menzerna 106 fa.
                        INAINTE
                        www.ozcarwash.ro
                          www.ozcarwash.ro
                            BEFORE
                            AFTER
                            BEFORE&AFTER
                            www.ozcarwash.ro
                              Headlight Restorations RENAULT LAGUNA
                              www.ozcarwash.ro
