NXT wax
  • NXT wax
    So I bought some of the NXT paste wax the other day. WOW!!! Only 1 problem though, It was a little chilli out. It was alittle hard to get it off. It didn' t dry all the way Im assumeing.
    Nxt paste wax
    I posted this in the wrong room before. I bought some the other day and WOW!!! Only 1 prob. I think it was to cold out cause it took a lot to get it off. I guess it didnt dry all the way.
      Re: NXT wax
      How long did you allow it to dry before removing?
      --Al Kimel
        Re: NXT wax
        that or you applied too thick. 2 thin coats are better than 1 thick coat
        - Markito -
          Re: NXT wax
          Low temperature and a heavy coat will both extend the drying time and possibly make the product a bit difficult to remove. Applying it a bit heavy when temperatures are below 55F will likely cause some noticeable changes in the behavior of the product. Just how chilly was it when you waxed?
            Re: NXT wax
            Not sure was alittle nippy out when i applied. Then it got alittle cooler. Im sure it was to thick and cold. I will apply thinner coat next time.
              Re: NXT wax
              Was it nippy and dry or nippy and humid? NXT works best if you apply it so thin you can barely see it....at least in my experience. Especially if the humidity is high.
              Black......the ONLY color!
