I just carried out wash/clay/(polish)/wax by hand on my well look after light color car. I encountered issue with the DC Polish, it seems to be effecting the surface after I applied it following claying step i.e. running fingers across the surface after claying was smooth but after DC Polish the surface became rough/partical-like (test done after I wiped off Polisher immediately after applying the polish).
The micro-fibre polishing cloth I used were reasonable clean and of high quality, claying and polishing have different MF cloth.
I couldn't tell if polishing application foam pad pick up further dirt/contiminant following claying, as the DC Polish is muddy grey in color to begin with. I worked in a closed and cool garage.
Question: Is this common or is there anything wrong with the DC Polish?
Your comment is appreciated.
PS: However, after applying the NTX 1.0 following the polishing step, the surface seems to return to smooth feeling again. To avoid having ruining my car, I avoided using the Polish after experiencing this when I applied it on the car roof, hence bracket on the (polish) mentioned above.
