How to add a border to a picture using Adobe Photoshop
  • How to add a border to a picture using Adobe Photoshop
    In this tutorial, I will show you how to quickly and easily add a border to a picture in Adobe Photoshop.
    Here is the picture I will be using.
    Step One
    Open up your picture (Ctrl + O).
    Step Two
    Go to Select --> All (Ctrl + A). This will select the entire picture so you add the border to the whole picture.
    Step Three
    Go to Edit --> Stroke.
    Step Four
    The "Stroke" dialog box will pop up.
    Width- How wide, in pixels, your border will be.
    Color- What color you want your border to be.
    Location- Choose "Inside" so it will not change the dimensions of your picture.
    Mode- Leave it on Normal
    Opacity- How opaqe you want your border to be. Leave it at 100% for a completely black border.
    Click OK when you are done to move on.
    Step Five
    Go to Select --> Deselect (Ctrl +D). This will remove the selection.
    Step Six
    Go to File --> Save As... (Shift + Ctrl + S).
    Remember: Make sure when you go to save the file, use the "Save As..." option to rename your picture. This will prevent you from saving over your original copy of the picture. If you do, there is no fixing it. Here's a tip: When I edit a picture, I like to copy the original and edit the copy so if something like that does happen, I did not ruin the original picture!
    Written by Tyler Clegg (roushtage2) for Meguiar's Online Forums. If you find any errors, please let me know so that I can get them fixed! Thanks!
