Foaming Dirt lifter
  • Foaming Dirt lifter
    I have seen and used a few different brands of "foaming dirt lifting" products that work pretty decent.
    My main use for these products are to make the crevices inbetween seats clean, where all the dirt and dog fur seem to accumulute . A foam action dirt lifter would loosen the junk up so I can then vaccuum them out along with the foam. Honda Accords are notorious for having these little "dead zones" where no matter how much vacuum power you have or what brushing devices you stick there will pull stuff up. Even duct tape on a stick does not work ( I've tried) .
    A multipurpose foam action dirt lifter would be another wonderful Meguiar's product. I also think that a several inch spray nozzle adapter ( included with each can) would be great. The purpose of this would be so that the product could easily be sprayed into the crevices inbetween seats. The main uses for it would be on carpet, upholstrey, vinyl, plastic, rubber, and probably metal as I have seen other products that can be sprayed on just about anything. I assume this product would smell good , but an apple scent would be too cool.
    Thanks Mike,
    Rich
    Hi Rich,
    I'll pass your suggestion along, and add that the new All Purpose Cleaner has been formulated to offer high foaming ability. You can spray it using a foaming spray head like the one found here, Foaming Sprayer
    I'm not sure if this will help you or if it's what you're thinking of, but I thought I would point this out anyway.
    Thanks for the suggestion, I'll pass it on.
      Imagine applying that via foam gun
      my product collection-- New !
      My Detailing Credo
      Treat it like it's the only one in the world.
        I actually brought a similar product up not too terribly long ago as well....
        I believe a product that foams slightly when sprayed onto the surface would be a plus. This foam could provide a media to dislodge and 'float' away dust and other surface items as well as the media for lubrication across the painted surface. I vision this product similar to Dow's Scrubbing Bubbles characteristically without
        I think it'd be a 'hit'!
        RP
        -The Final Detail-
        Lagrange, Kentucky
        thefinaldetail@insightbb.com
